Question about Dometic RM2193 Compact Refrigerator With Ice Box
Can you transport these refrigerators laying down? if OK which way would be best, side, front, back
    Sergeant:
  • 212 Answers
No. don't try to do this. you will get oil from the compressor into the evaporator. it will be very expensive to fix. if this happens then your unit will not cool properly
Posted on Jun 22, 2009
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
GE model GTS22WCP can I lay it on it's side or back to transport?
it is not recommended to lay an appliance with a compressor, the reason is that the compressor oil will run to one side and the appliance will not function properly. i have heard that if laid down the make sure to stand the appliance upright for several days before plugging it in.
Aug 08, 2012 | GE GTS22WCP Top Freezer Refrigerator
I have to transport a refrigerator - Model # ED25PWXBW00 (side by side) approximately 100 miles. Can I lay it down? What will happen if I do?
As far as I know, you can transport a refrigerator laying down but you should leave it upright for 24 hours BEFORE you plug it in.
Aug 22, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Need to transport an Admiral refrig about 20 miles to my home. Can I lay it on its back or side. It's a newer model, within 5-7 years old, I'm guessing. Any problems doing that/
Hi Bill
Its not the best idea to lay it down at all, inside the "pot" the compressor is suspended on 3 springs and it can get dislodged which wreck the compressor. However if you can lay it over at not less than 30 degrees from the horizontal (maybe in a pick up) and try not bounce it too much you should be OK.
IMPORTANT, VERY IMPORTANT, WHEN YOU GET IT HOME IT NEEDS TO STAND UPRIGHT FOR AT LEAST 24 HOURS BEFORE YOU SWITCH IT ON
This is because some of the oil from the compressor can get swirled out around the system when it's transported, if you do not give it time to migrate back then the compressor WILL SEIZE UP
Hope this helps
Gordon
Apr 20, 2011 | Admiral Refrigerators
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
Can you lie a Magic Chef 4.4 cuft. refrigerator on its side to store it for a few days and transport it or does it have to be upright?
Yes, you can lay a refrigerator down.... but...
Before you move that thing read this tip about how to lay a refrigerator down so that you will not hurt it...
Moving a Refrigerator What is the best way
heatman101
Aug 31, 2010 | Magic Chef Refrigerators
Can you lay a refrigerater down flat to transport it
Yes as long as the coils that carry the freon is located on the top side of the compressor when laying down. Look at the lines on the compressor. You should see 2 of them. 1 larger than the other. Imagine you are tilting the refrigerator. If the lines are on the right side you can it down on it's left side ok. If they are on the left side you lay the fridge down on it;s right side. Hope this helps.
Feb 13, 2010 | Refrigerators
Is it ok to transport a refrigerator on it's side?
Not true. Refers since the 1950's are sealed units but for safety's sake let it sit for awhile after you move it.
Aug 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Dometic RM2193 Compact Refrigerator With Ice Box Logo
451 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
