Question about HP Officejet Pro 8600
How can I clear backed up documents from printer que
    New Friend:
  • 29 Answers
If you have windows, in the taskbar, in the low-right corner, near the clock you might have a printer, which is set to Offline. Therefore all your documents sended to printer are queued in the driver. Enter on the printer manager and Cancell All Documents.
Posted on May 07, 2014
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
My HP 960c won't stop printing. I get mostly blank sheets with jibberish at the top, but it's continuous.
Turn off the printer. On the computer in the lower right by the time, there should be a printer icon, double click it. This will open the print que. Select all documents in the printer que and delete or cancle them. You may have to reboot the computer for this to clear completely. Once the que is clear, turn the printer back on. Do a test print to the printer and see if the issue is cleared up. If not you may need to reload your print drivers.
Hope this helps you
Dec 16, 2011 | HP DeskJet 960c InkJet Printer
I want to clear the que. I tried to print a page and it will not print. It has remained in que for two days. I have tried to cancel it, didnt work. I unplugged the printer and usb cable, it still did...
If you are using windows operating system than go to Printer and Faxes, Double click on the printer icon. A window with printing document que will appear, click on "Printer" and select "cancel all documents" and then switch off the printer for few minutes. the document que will disappear.
Aug 12, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
I have a document in the que which I can't delete
Shutdown the PC . Then just pull the power plug from the back of the printer for 30 secs.
Afterwards turn on the printer first, then the PC. It should clear out.
Sep 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
Document locked in que
Solution #1 Have you tried to power off the computer itself? The document is most likely locked in the PC not the printer. Unplug the printer's power, power down the computer, wait a minute or so then restart the computer. Once the machine has loaded check the print queue to verify the document is no longer there, if so you can plug the printer back in and the issue should be resolved.
Solution #2
From the Start menu, select Control Panel. Then follow this path:
Administrative Tools > Services > Print Spooler
Once at the Print Spooler, right click on it. Select Stop. Leave this window open. Turn off your printer.
At the open Print Spooler window, right click on the Print Spooler, and select Start.
Go to the Start menu, and select Printers & Faxes. Find the printer you are having problems with and double click on it. From the menu, select Printer, then select Cancel All Documents. The documents should clear.
Turn on your printer. You sould now be able to print.
Oct 15, 2008 | HP PSC 1350 All-In-One Thermal Printer
Canon imagerunner c3200 stuck in processing data
If you don't print via a server,you can turn the iRC3200 off...then back on and that will clear the print jobs.
If after doing this it STILL has a traffic jam in the print que when trying to print the same document then stop sending THAT particular document as the document has a formatting issue and NOT the printer.
If you DO use a print server then you(or your I.T Professional) need to go to the server and clear the print jobs from the server.
Aug 06, 2008 | Canon imageRUNNER C3200 Copier
Epson R300 "GENERAL ERROR SEE YOUR PRINTER DOCUMENTATION FOR INFORMATION ABOUT CLEARING THE ERROR".
in my r300 epson printer general error appear . How can i remove or clear this error from my printer lcd
Feb 01, 2008 | Epson Stylus Photo R300 InkJet Printer
HP Officejet Pro 8600 Logo
48 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
