Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
HP colorlaserjet 2840 shows no ink
I replaced the yellow with an off brand, worked fine for a couple of weeks, today it showed no yellow, I tried pulling it out and putting it back in. Now it shows no ink in any of them.
    Sergeant:
    Champion:
  • 253 Answers
Always use original hp cartridges and now u shud get ur printer checked by technician or if u want our technician help contact us at http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Ink system failure, won't reset, won't respond to cleaning
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
having the powercord from printer straight to a wallsocket? If it is not a mechanical issue, try this.
In menu, go to service, choose restore defaults. Then try upgrade firmware for printer.
Nov 03, 2008 | HP LaserJet 2840 All-In-One Printer
Problem with new ink cartridge
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Oct 29, 2008 | HP PSC 1410 All-In-One InkJet Printer
Hp laserjet 2840 all in one gives FUSER ERROR
For any fuser error, the first thing that should be done is replacing the fuser. If the error still shows up after wards, it could be the LVPS (Low voltage power supply) or a board.
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
