Question about Music
Who is the speaker of the following qoute and to whom was it told "she was a white and she tempted a niegro.she did something that in our society is unspeakable she kissed a black man" give an explanation of the event
    New Friend:
  • 29 Answers
This is the entire quote of Atticus speech during the court hearing in Chapter 20 of Harper Lee's To Kill A Mockingbird
Posted on May 07, 2014
How do i change the woofer in the eurolive B215d..does the front screen pop out
Yes, the front screen should just be a compression fit. Something a bit stronger than a paperclip should work fine to pull it out. Work around the edges.
Jan 18, 2015 | Behringer Eurolive B215DWH 550W 2Way PA...
I have A Technics PR-305 Digital Piano I have a Distortion in my speakers I was told that it would be wise to replace the speakers Where would I go to replace the speakers?
That depends on where you live and if you want to replace them yourself. If you do then you need to make sure they match what you have, (impedance, wattage etc)
Feb 01, 2014 | Music
I Have a Technics PR-305 Digital piano that I have for a little over 12 years ago that I enjoy playing on very much, I have a distortion problem in my speakers it`s not very bad I was told in Fixya th
The Speakers can be replaced with any brand. The thing you need to know is the OHM rating for the speaker. OHM is also called impedance. Unless the sticker has fallen off the back of the speaker that information will be on that sticker. OHM rating MUST match the old speaker. For instance 4 OHM, 8 OHM, 16 OHM are common ratings. All different ratings but VERY important to get this correct otherwise you could damage the electronics of your instrument.
Aug 13, 2017 | Music
My sound active mode is not working correctly. it goes at a fast pace even turned all the way down.
If you're sure you're in sound mode then it sounds like yet another faulty chauvet unit. Buy something from a better manufacturer and you've got a chance but in our experience Chauvet are a rule unto themselves and the kit is not worth buying. We have had nothing but trouble with them and no longer buy their kit no matter how tempting the price.
Jan 27, 2014 | Chauvet 4play Led 4 Play Dmx Moonflower...
Mackie mixer overheats
Cleaning may be an issue, maybe try putting something under it to air can get to the bottom. I've had to do that with my mixer.
Dec 30, 2013 | Mackie 1202vlz3 12 Channel Mixer
Blown speakers?
usually with a blown speaker you will get sound but it sounds like there is an abundance of paper very loose on the speaker, so if there is no sound at all try taking the box apart if you are familiar with stuff like this and check to see if there are any loose wires or blown capacitors
Jun 24, 2012 | Behringer Music
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
When i power up my line 6 spider 3 ( i think it has two 75 watt speakers) all the lights work but no sound at all no static or speaker sound even at full volume. cable checks out, but even with a bad cable...
A pilot light means almost nothing other than the power cord is plugged in and hot and the switch is on. In this case, other lights run from various DC supplies so the inout fuse is presumed to be good... NEVER replace a fuse without knowing what caused it to blow or you will usually do more damage within a unit. There are several power supplies and you will typiclly find +/-15 volts on the op amps and 3.3 volts on the processor logic. Unless something simple like the speaker cable falling off this will NOT be a DIY repair. I would look to see if this speaker cable might have fallen off and ALSO check if you get any sound using headphones.
Nov 06, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
I just got a kaoss pad and having need help connecting to a cdmp 6000 help please
You haven't got a send and return on your cdmp 6000. What I advice you to do is the following: connect the master out, the red/white cinch, to the input of the kaoss pad. Than connect the output of the kaoss pad to your speaker system or reciever. You can now control effects on the master single.
Feb 20, 2010 | Korg Mini Kp Kaoss Pad
Music Logo
104 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
