Question about Logitech Audio Players & Recorders
When I have on my headset I can hear myself talking and there is an echo.
I can hear myself talking through my headphones but there is an echo that is annoying. The person on the other end of the call does not hear the echo. I have tried this with various calls and it is only on my end.
SOURCE: H500 bluetooth headset
Turn down the volume on the PHONE, not the headset. Motorola 325i w/ H500. Again, turn down the volume on the PHONE, not the headset. In my case almost all the way down.
Posted on May 02, 2007
PungaA
  • 91 Answers
SOURCE: Can't deactivate headset
Did you check the connector on the bottom of your phone ? If theres any greenish stuff (oxidation) on the connectors/pins, there's your problem. This occurs if the connector has been exposed to moisture. If this is the case you can try to clean off as much as you can and it might correct the problem. But if this doesn´t work, the problem might be inside your phone. If you're up for it, you can take it apart yourself and try to clean the inside of your connector. If youre not up for it, or the connector is clean, take the phone down to your local service-center and have them take a look at it.
Posted on Oct 05, 2007
SOURCE: GN Netcom GN 9120 - can't hear
Hi There, I had the same problem with a headset one of our call centre reps were using. It's usually due to some one fiddling with the button. I got it working by removing the battery from the headset then resinked the headset to the base unit. Hope it works for you
Posted on May 19, 2008
Peter Denton
  • 16 Answers
SOURCE: New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Posted on Nov 05, 2008
SOURCE: MOTOROLA H800 WIRELESS HEADSET
I took mine apart to see what the problem was, the two wires that go to the mic had be broken. Probably by the sliding motion of the boom. Gonna try to fix it if i can..don't know, It will probably do the same thing again. Always remember- THE MORE MOVING PARTS TO SOMETHING THE MORE THERE IS THAT CAN GO WRONG!
Posted on May 16, 2009
Cs540 caller hears echo
Hello, if they are hearing echo, you are speaking too loud. Or have the receiver too close and talking too loud. Or the person on the other end of the line has phone line problems.
May 16, 2014 | Plantronics CS50 Wireless Headset
Echos for person I'm talking to how do I fix this
Ann
Does this always happen? Have you tried a reset?
HX550 Reset to factory default
Mark
Motorola Support
Mar 27, 2014 | Motorola Mobility HX550 Bluetooth Headset
Can't hear myself talk
Dan, You should be able to hear yourself inside your head as the small hairs that vibrate in fluid in your ear canal will pick up your vocalizations. In any case you know what you're saying and it shouldn't be a problem talking to someone.
Now if you're listening to music really loud on those headphones and still need to hear yourself think, I suggest you turn down the volume. :)
Jul 16, 2013 | Creative ChatMax HS-720 Headset
Friends hear echo when headset is on in x-box live party chat
I had the same exact problem with a brand new x32 headset. right out of the box it was echoing for my friends. Also, if I muted my mic it would kill the chat volume (ie barely even audible). I switched the voice to play through speakers and it worked flawlessly after that.
Not sure if it is a hardware issue with my controller (my other headset worked just fine) or if it is a defective cable I received, or a design flaw with the x32. If you are looking for a work around, try setting it to play through speaker.
May 15, 2012 | Voyetra Turtle Beach Tbs-2265 Ear Force...
When I talk no one can hear me but I hear them
If your X3's microphone is working, you should be able to hear yourself in the headset when you talk into it. Plug the chat-controller cable in both the headset and the controller, then talk into the X31 mic. Can you hear yourself in the headset? If yes, then the microphone is OK but you probably need a new chat-controller cable. If not, then the microphone may be broken and you should contact Turtle Beach tech support at support@turtlebeach.com.
Feb 28, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
I can hear normally through my x1 headset. But
Check the X1 mic on a laptop or PC to make sure it's working. If not, then the mic needs to be fixed. If it's ok on the PC, then you might need a new talkback cable which you can buy at this link:
http://www.turtlebeach.com/products/efx1/replacementparts.aspx
Dec 31, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
When its on, i can hear what other people are saying, but they cant hear me talk
Well, this happened to me before, it wouldn't let me talk to them and I could only hear them. The problem is the cord, you have to go out and buy a new one I'm afraid. If it is new though, then it is defective.
Nov 21, 2009 | Microsoft Headset for Xbox 360
When i talk to people my mic echos realy bad and cud some1 help
Do you have an X1? If so, you should be able to use it with a PC. Try talking into the mic with your X1 connected to the PC. Does it echo there too? If not (and it shouldn't) then you probably only need to replace the chat-controller cable with a new one. Those are available for sale on the Turtle Beach website (www.turtlebeach.com). Turtle Beach tech support is support@turtlebeach.com.
Mar 05, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
They all here an echo!
the h700 version 1 is known for an echo to really remedy this problem you need to upgrade to h700 version c because this headset has noise canceling intergrated into this model get one cheap at www.n1wireless.com
Dec 17, 2007 | Motorola Mobility H700 Wireless Headset
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
