How to install primavera contract manager V12 on windows 7
SOURCE: Primavera Project Planner P3 unable to be
as for as i know,if u hav windows7 professional and above versions no problem.u can download virtual machine and u can switch to win xp virtual mode.in winxp u can install p3.1.if u r having win7 home premium,there is no virtual mode.i am still searching for answer.
Posted on Mar 08, 2010
satish rana
  • 18 Answers
SOURCE: i am using windows 7 64 bit home edition i cannot
it may be your pimavera project mangement not to support 64 bit it can be it support 32 bit reinstall you primavera project management release and then restart your compute.frist see the configuration of your software database
Posted on Apr 03, 2010
SOURCE: Running Windows 7 and Adobe
It has to do with the file name including the path being longer than 63 characters. Copy the file to a shorter path, i.e. c:\a\ and try that.
Posted on Sep 01, 2010
bunnydawg
  • 5158 Answers
SOURCE: How to install Primavera Project
You can make it compatable for win 7. When you install the program, right click on the install icon. on the list that pops up you will see troubleshoot compatability. choose that. when the wizard pops up, chose the second option and click next. you will see a series of check boxes to help make it compatable. chose the first and third check box. click next. in the next window you can chose which version of operating system it normally runs under. pick the one that normally works (sometimes you just have to experiment for the right one). click next and click on the run the program button. install the program as you normally would. it should function properly after that.
Posted on Jun 15, 2011
SOURCE: i have a problem installing primavera 6.2 on Window 7 Home preminum
I suggest you begin by doing a Disk Cleanup, then a disk Defragmentation and a reboot. Try installing primavera again, but refer to the installation instructions and follow them precisely. All the best.
Posted on Jun 20, 2012
I just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect
You must connect to a database to utilize Primavera. You can not bypass this portion. So, Either remove the Database and reconfigure, or in the "Configure" Screen you can Name a new DB and use it. I would suggest that if you do not require 2 DB's not to have two. "The Oracle Database 10g" application that is installed with P6 (In your 'All Programs') will give you some DB manipulation options. Other wise refer to the TenSix link to clarify DB Config
http://www.tensixconsulting.com/2013/03/primavera-p6-database-connection-configuration-details/
Feb 13, 2013 | Primavera Contractor 6.1 Full Version for...
I have a problem installing primavera 6.2 on Window 7 Home preminum
Jun 20, 2012 | Primavera Project Planner P3 (PRIMAVERAP3)...
How to install primavera3 32bit to a laptop which is 64bit
Hi, I am assuming you are using Windows 7 64-bit. Primavera 3 probably does not work in Windows 7.
Try running the installer in compatibility mode or if you have Windows 7 Pro or Ultimate you can use XP mode.
Compatibility Mode
Windows XP Mode - Install and Setup
Other alternatives, downgrade to Windows XP or upgrade Primavera
Apr 12, 2011 | Computers & Internet
I originally ran my Suretrak on Windows xp. I have now loaded it onto my new computer running Windows 7 Home at 64bit. The program is not completely functional. Is there an upgrade or fix that resolves...
Suretrak is not fully compatible with Windows 7. We have talked to Primavera on this issue and they say they will continue to support Suretrak for at least another year but have no plans to upgrade Suretrak to the Windows 7 platform.
Aug 11, 2010 | Primavera SureTrak Project Manager 3.0 for...
I am using windows 7 64 bit home edition i cannot able to install the primavera project management release 6 ( cannot configure database)
Apr 03, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
Can't configure the database connection for Primavera p6
i just installed Primavera Project Management , and Methodology management. After logging in with the default username of admin and password of admin it comes back with the message " Unable to connect to the database. Would you like to configure the database connection now?" How do I get around this challenge? iam using vista
Feb 05, 2010 | Primavera Contractor 6.1 Full Version for...
Im not able to instalthe primavera p6 on my new hp lap windows 7
Before installing primavera p6, check whether any SQL databases with the same name exists. Uninstall the SQL if the databases created during the previous failure installation of primavera p6(go to add or remove programs to uninstall). After uninstallation of SQL express, try to run installation files for primavera p6 will solve your problem.
Revert back for more assistance.
Dec 26, 2009 | Computers & Internet
Which version of windows 7 goes with primavera 6
It works with Win 7 Ultimate, but it should work with all versions -you need to install SQL Server SP3 BEFORE running P6 for the first timethough...
SQLServer2005SP3-KB955706-x86-ENU.exe
Nov 17, 2009 | Primavera Project Planner P3 (PRIMAVERAP3)...
Computers & Internet Logo
David Payne
David Payne
