Question about Sony Cdx-gt56ui In Dash Car Cd Player W Radio Receiver Head Unit Aux Input
Sony cdx gt56ui reset button...where? - Sony Cdx-gt56ui In Dash Car Cd Player W Radio Receiver Head Unit Aux Input
4 Suggested Answers
SOURCE: Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Posted on Sep 06, 2008
  • 1126 Answers
SOURCE: hOW DO I RESET THE SONY CDX-T69 6 CHANGER?
http://www.manualshark.org/m/sony-cdx-t69-operating-instructions-2319/
Posted on Jul 08, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Posted on Oct 01, 2009
Will the Aux. Input port also work as a earphone system to listen to any audio. This system is in a convertible & this option would be nice going down the road...top down.
aux input is exactly that an input system ( mic , other input device etc)
you need a head phone socket for what you want to do ( output socket)
Jul 05, 2015 | Sony Cdx-gt56ui In Dash Car Cd Player W...
Is there a reset button?
If it has an antitheft built into it it Will not work untill you enter a code you can get this code by pressing buttons on the radio search the internet for how to
May 07, 2014 | Sony Cdx-gt56ui In Dash Car Cd Player W...
I just install a cdx-gt56ui stereo to my 2001 silverado truck... I tried hooking it to a harness but it didn't work,,, so I tried hooking it directly to the wires but I can't get the unit to p
the factory radio is databuss, like a computer, comparable to modern call phones. they sell an interface module that plugs into the factory harness plug, and you wire into that.
Sep 01, 2012 | Sony CDX-GT56UI
How to reset my sony cdx-gt55uiw
Detach the front panel and press the RESET button with a pointed object like a ballpoint pen. Full details are on page 6 of the manual.
Aug 03, 2012 | Sony Cdx-gt55uiw Xplod Car Audio/stereo...
Which wires do I use for the acc/battery on Dodge Dakota for Radio
One wire stays hot all the time (yellow) and acc is only hot when the key is on. you should be able to find the wires in the original wire harness to the old radio with a test light or a meter.
Jun 09, 2012 | Sony Cdx-gt56ui In Dash Car Cd Player W...
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
It seems like it is in demo mode, buttons don't do anything, it just keeps saying what it has. ie sony, mp3, cd, eq presets... etc.
ı have this problm too ,how can we fix this problem and i couldn't find the reset button of cdx-r3300 s- mosfet..in its manual somewhere is defined but in my equipment there doesn't exist a reset button :((( heeeelp...
Dec 12, 2009 | Sony CDX-R3300 CD Player
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Jan 16, 2009 | Sony XPLOD CDX-GT200 CD Player
Cds stuck in sony cdxt69
Take power away for 5min then plug back up. Hit reset with pen head.
Sep 17, 2007 | Sony CDX-T69 6-Disc CD Changer
Sony Cdx-gt56ui In Dash Car Cd Player W Radio Receiver Head Unit Aux Input Logo
146 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
