Compressor starts stops
My ac compressor starts and stops after every five to ten minutes.
  • 884 Answers
Check the fan is running to cool the condenser, and the condenser is nice and clean
Posted on May 07, 2014
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
  • 252 Answers
SOURCE: LG Window AC Problem
send it back again!
Posted on May 03, 2009
shastalaker7
  • 1515 Answers
SOURCE: The airconditioner runs and blows cold ai. When
Hi, the only thing that could cause this to happen would be the thermostat. This is the main part that controls the roof top unit, getting its signal from the stat to come on and maintain the correct temperature. I would replace it with the same type and this will solve your problem. The only other thing that would cause any unit to cycle like this is if you had bad thermostat wiring touching together some where. I don't think this is the problem with yours though. With the stat off and it still cycles on, this tells me for sure it is the stat. Change it out and you will be good again.
Sincerely,
Shastalaker7
Posted on Mar 26, 2010
bobicehouse
  • 1524 Answers
SOURCE: COMPRESSOR RUNS FOR TEN MINUTES STOPS AND WILL NOT COME BACK ON
Check amperage while unit is running.
Posted on May 08, 2010
SOURCE: My AC stops every five minutes and restarts after a while.
i hanve 1.5 ton window air condtioner.compressor of a.c runs for 2 min and he it cuts off after 3 min it again starts
Posted on Jul 27, 2010
Polo screeching sound
It's probably a worn or loose (or both) drive belt
Jan 30, 2013 | Volkswagen Polo Cars & Trucks
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
Sep 13, 2012 | 1999 Ford Taurus
99 durango ac stops working
could be many things too much gas less gas air in the system.
Aug 06, 2017 | 2000 Dodge Durango
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Freezer chest compressor keeps cycling on and off every five/ten minutes continuously. Thought it should cycle every couple of hours.
Change the starting components (relay, overload, capacitor if so equipped)
Bi Coastal Appliance Parts @ 1-800-673-1262
Mar 23, 2011 | Haier Chest Freezer HNCM070E
Feb 17, 2010 | Samsung AW1293L Air Conditioner
AC Compressor Cuts Out
Do you have gages you can hook up?check preasure when A/C clutch is on preasure low should be about 30 and high should be about 180,if high side is higher you got a blockage some where usealy they will plug at the recever dryer or the expansion valve
Jul 28, 2009 | Ford Ranger Cars & Trucks
91 chevy 1500 ac light flashing
try disconnecting the negative battery cable for ten minutes to reset the computer.
good luck
Jun 24, 2009 | 1991 Chevrolet K1500
send it back again!
May 03, 2009 | LG Heating & Cooling
FRS26KR4CB1 side by side refrigerator
It sounds as if you have a defective compressor start relay.  It is located on the side of the compressor, usually contained within a black plastic housing (box).  If ordered, it will most likely come with an overload proctector.  Change both parts.
Oct 13, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
