Question about Water Heaters
Maytag series 12 water heater
Water heater over heats and kicks it's braker. I reset the braker and heats the water super hot and then kicks the braker again. The lower part of the heater has been under water
  • Water Heaters Master
  • 5,089 Answers
  • 2692 Answers
SOURCE: top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Posted on Jan 24, 2009
  • 34 Answers
SOURCE: water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Posted on Feb 08, 2009
snap101
  • 117 Answers
SOURCE: Code 11 01 - Hot Water Heater Kicks Off
if you have build up in the heat exchanger it will cause the unit to use more gas to heat your water, if the gas line isn't sized properly then your going to kick the error codes off. it sounds like you have two problems, first you have build up in your heat exchanger and it needs to be flushed and second you need to get a bigger gas line to it
Posted on Aug 22, 2009
  • 244 Answers
SOURCE: PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Posted on Dec 06, 2009
SOURCE: I have a GE hot water heater, SE40M12AA01, dual
1) You posted under Rheem-GE electric water heater.
If upper element is burned out, then water heater will not heat any water.
http://waterheatertimer.org/How-it-works.html
2) Replace upper element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Open following link for complete troubleshoot:
This troubleshoot assumes you have standard thermostats and elements.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
4) Manuals and links. I do not see 'smart lights' in the manual.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Standard_Water_Heaters
Troubleshooting starts page 15.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=AP12168-7%20%28GE%20Elec%29.pdf
5) Add a comment with your experience so other with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 26, 2011
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
No hot water at all. Have tried resetting, but still nothing. Is it the heating element what needs to be replaced?
Get a multimeter and check power first. If you have power going into the water heater, proceded to replaced the heating element. The replacement can only be done by empting the tank and turning the brakers off. Good Luck!
Jan 13, 2014 | Bosch Ariston GL4 GL4 Point-of-Use...
Recently purchassed system from you plumber installed it and we asked specifically not to set it on child settings.....we have not had one HOT shower since. how do we go about resetting the hot water...
These Tankless water heaters attempt to heat water as it quickly travels through a short series of heated copper pipes. A high volume of water at an accelerated speed has little time to heat up as it passes through its heating source. You can turn up the temperature (which you undoubtably tried) and turn the water volume all the way down. These settings will produce the hottest temperature capable of the unit - given the entry temperature of your water source.
Most underground water enters at app 52 degrees - and becomes even colder due to ambient temperatures. Difficult to raise this temperature 60-70 degrees in a few seconds of heating.
I've routed a series of copper pipes adjesent to the home heating system in an attempt to pre-heat incomming water. It's only a few degrees warmer, but results a 20- 30 degree hotter delivery.
I have installed some top end units that simply delivers Hot water without compermise.
Mar 01, 2011 | Bosch & Tankless LP Hot Water Heater
Elec water heater 40gal water way to hot and blowing braker on the water tank Red reset button what wrong please help
One of the thermostats is bad or there is corrosion behind it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 14, 2011 | Water Heaters
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
heatman101
Jan 03, 2011 | Reliance & Lowboy& Electric Water Heater
How to operate Rinnai V1500 water heater?
The V1500 is in essence the same as Infinity 26. Rinnai have manuals on their website.
Here's a link
http://www.rinnai.com.au/images/stories/operating_instructions/Hot_Water/All_Continuous_Flow.pdf
If you have any specific problems or queries just post them on this site. I check it every few days.
Cheers
Aug 15, 2010 | Water Heaters
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
