Question about Kenmore 51lb. Clear Ice Maker
I have kenmore freestanding ice machine. Water flow fine, will not cool. Can I add free on and if so where
  • 2 more comments
  • Intellectual Habitat
    Intellectual Habitat May 07, 2014
    Mod 106, 89483993. Water comes in and condenser is clean. I do not hear the condenser kick on but I am not sure how load it would be. New unit to me. Inside of unit is hot
  •  Pleazer Appliance
    Pleazer Appliance May 07, 2014
    You would be able to feel air movement at the nase of the unit, air is pulled in throught he coil and exists on the left side. This unit most likely does a 60-90 second fill then rinse, then another 60-90 sec fill, tehn commences ice making. Best to follow the questions I posed to narrow down your issue. Pleazer Appliance...
    I do not feel any air movement on front of machine.
  •  Pleazer Appliance
    If the toe kick has been removed at the bottom you can also check for a warm copper line entering the condenser coil, either top or bottom should be warm if the compressor is running, you also need to check that the water is cascading over the freeze plate after the 2 fill and rinse intervals. If the water is cascading over the freeze plate and running back down into the resevoir, but the condenser fan or compressor isn't running, than you most likely need the main control board replaced located in the ceiling box where you select the functions. Pleazer Appliance...
    Novelist:
  • 150 Answers
You do not add freon to these units, they are sealed, no access ports installed from the manufacture. If you are actually low on freon than you have a leak and will just end up in the same place you are now. Some things to note since you have not posted a model number. Does the water come into the reservoir when you first turn it on? Does the water circulate over the freeze plate shortly after it's done filling? Is your condenser coil on the bottom behind the toe plate completely clean of dust? With the toe plate off are all of the components running, like the compressor, and fan motor after your fill time has expired? Please add a complete model number from the sticker on the unit for better advice. Pleazer Appliance...
Posted on May 07, 2014
    Intellectual Habitat Mod 106, 89483993. Water comes in and condenser is clean. I do not hear the condenser kick on but I am not sure how load it would be. New unit to me. Inside of unit is hot
Ice machine won't make ice! kenmore 363.9537883 bought whirlpool filter 4378411RB water comes out of door but pressure isnt good. Told me i needed a new filter. Is this the problem or something else?
The filter is for water AND the ice maker. The ice maker expects a certain amount of water to flow into it during the fill time. If no water flows at all into the ice maker, then suspect the clock mechanism of the ice maker.
Aug 14, 2016 | Kenmore Refrigerators
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Ice maker water dosen't work
HI CHECK WATER SUPPLY FIRST.WELL ICE MACHINE FIRST.ITS ON RIGHT?LEAVER DOWN?IF ALL GOOD CHECK VALVE.GOOD LUCK.ALI
Jun 25, 2012 | kenmore.com
Kenmore 596.50692001 side by side stopped cooling. The fan is working, the compressor kicks on for less than a minute then kicks out. No cooling air flows. Water dispenser is working fine, but the water...
You most likely have a fried overload, it is the small white square shaped piece on the compressor, to tell if it is bad, remove it and smell it for electric burning smell, or if you shake it and it sounds like sand shaking around it is definately bad. costs around $25 to replace. You can purchas this at http://www.reliableparts.com/ using your model number.
Dec 01, 2010 | Kenmore Refrigerators
I have a hosizaki ice machine. the warning buzzer is continious. is it the control board?
check to see if you have the correct water pressure going into the machine. You need at least 30 psi. Also if your machine is water cooled, be sure cooling water is entering the machine. on water cooled machines there will be a continuous flow of water into the drain whenever the machine is running. If it is air cooled check the condenser coil to see that air is flowing freely through the coils.
Sep 11, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I have a kenmore model 106 79207990 Water and Ice developed behind the frezzer tray I took the tray out and it appears that the drain was filled with ice. What seems to be the problem with the drain....
The drain can get a build up in it over time or a foreign object can get in there and block the water flow.
To clear the drain:
- Turn off the refrigerator and unplug
- Locate the drain (it may be under all the ice) it is just below the cooling coils close the slots in the back panel. The drain hole is about the size of a dime.
- Use hot water and bath towels to unthaw the ice, DO NOT use a chisel and hammer as you can cause damage. A hair dryer may work too but be careful not to melt any of the plastic walls.
- Once the top ice is gone, use a turkey baster to flush down the drain hole until the water flows free.
- A small amount of spilled water on the floor is normal while doing this so have towels ready.
Apr 18, 2010 | Kenmore Refrigerators
I have a Kenmore Elite top freezer refrigator. Water is driping or somehow forming on the top shelves [under the top freezer] and a thin layer of ice will appear and the water contuniues to form. then over...
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 02, 2009 | Kenmore Refrigerators
Ice maker problems
hi thanks for the question when you switched the wires around you checked the valves . tey are ok is the arm in the ice maker down check that if that's ok then the problem is with ice maker thanks for the question the appliance doc
Sep 23, 2008 | Kenmore 53642 / 53644 Side by Side...
No Ice on GE Side by SIde -TFX25JRYF-WW
Usually there is a big metal frame-switch that controls the flow of water. It is located right above the ice tub. If your ice tub is full the ice cubes push this metal switch up so as to stop water supply. If you remove the ice tub out, chances are that you have accidentally pushed the metal switch all the way up until it clicks and stays there. In this position, the ice mold water flow is permanently stopped.
Insert the tub again in its position slowly. Before fully inserting it, pull the metal switch down inside the empty tub. With the switch down, insert the ice tub back into position.
If that does not apply for your refridgerator, look for a similar water flow switch to turn back on the water flow.
Hope this helps
Mar 07, 2008 | Refrigerators
Kenmore 51lb. Clear Ice Maker Logo
168 people viewed this question
Top Kenmore Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you a Kenmore Kitchen Appliances - Other Expert? Answer questions, earn points and help others
