Question about Samsung RF4287HA
Controles off Star ing y off again
Star refrigerator off again both lights off
Has stoped makeing ice and none of the door controles work. model SH205298
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling. Freezer is working
check if the fan are working, or for easy to dianose, defrose the refridgerator the whole night and turn on in the morn ing. if still not working, check again the fan inside the ref, if no noise or cant hear the motor fan, remove and replace ok
Aug 30, 2009 | Refrigerators
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
My Inglis Refrigerator doesn't make ice anymore,
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Jun 23, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My control panel on my ge profile psc23ngpacc is not lighting, and the water in the door dispenser seems to have no power.
G E is going yhrough some changes and one is there now low energy cost compressor that constantly runs just at diffrent speeds. anyway the control circuit board controles everything and the first noticible problem is in the Ice despensor and display board. In most cases after the first replacement the will replace board over and over at no cost for the part that is how common theis part failure is.
Jun 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No power to the controles
sounds like bad batteries or blown fuse which is loacated on postive post of each battery.
Mar 27, 2009 | Invacare Supply Group Invacare Pronto M91...
Light off
probably just the bulb. look in yoiur instruction book and it will tell you how to replace. usually just a matter of removing the cover over the light
Jun 08, 2008 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Ice maker
There is a slide switch near that flashing light. Move it to on.
Jan 03, 2008 | Whirlpool GS6SHEXNL Side by Side...
Samsung RF4287HA Logo
18 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
