Question about HP DeskJet 6988 Printer
Why won't my printer let me remove the cartridges?
Printer won't let me remove the cartridges -- A little white thing has popped up with a power sign and an arrow on the left and a power sign on the right, in front of the cartridges?
  • 6 Answers
SOURCE: HP Officejet 7410 All-in-one No Power Light
Turn the printer upside down right underneath where the cartridge station is you will find a small white gear...sometime it may be covered with a blue rubber cover.
when you turn the gear ..the barrier in front of the cartridge will go down.
Then do a rest on the printer and then install it.
Posted on Jun 08, 2008
getbharti
  • 33 Answers
SOURCE: Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Posted on Nov 28, 2008
SOURCE: hp7310 printer remove and check cartridge on right error
I know this might not sound like a good thing to do, but it fixed it for me. I licked my finger and rubbed it on the circuit board on the cartrige, then put it back in the printer. It seems to be working fine.
Posted on Dec 21, 2008
SOURCE: Continue to receive "Remove and check black cartridge" message
Gotta love the internet!
I had the same problem...I seriously considered getting a new printer since I've had my faithful 5510 AIO for like, six years...but what I did was grab some witch hazel and a q-tip. Dipped the q-tip in, wiped down all copper contacts on the carriage and also on the print cartridge...blew on it to air dry...popped it back in and viola! It's back to normal.
Posted on Jul 09, 2009
sgoswami
  • 114 Answers
SOURCE: printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Posted on Sep 16, 2009
Why will my ink cartridge not move to the center so i can tak e it out.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Sep 10, 2011 | Lexmark X2470 All-In-One InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Aug 30, 2011 | Lexmark X2600 InkJet Printer
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
Print cartridge would not move to loading position to allow installation of new cartridge
Aug 17, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
When lid is up, cartridge carrier is not showing.
Apr 20, 2011 | Lexmark X4650 InkJet Printer
When i power up cartridge s do not center
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
Apr 15, 2011 | Lexmark JetPrinter Z55 InkJet
Cartridge housing will not certre to change cartridge
Apr 10, 2011 | Lexmark Z2300 InkJet Printer
PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
HP DeskJet 6988 Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
