Question about Electrolux ER6641T Compact Refrigerator
How can i fix a leak in my electrolux glrt182saw4?
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Geoff,
I see that you are trying to fix a leak in your Electrolux refrigerator, model# GLRT182SAW4. In this particular case, of your appliance leaking, I suggest contacting your local authorized technician. They will be able to diagnose your refrigerator, and determine what the cause of the leak is, so they can possibly repair your appliance. Hope this is helpful.
-Best Regards-
WP
Posted on May 12, 2014
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
How do i find the leak sensor on my electrolux dishwasher?
Good Afternoon Friend,
I understand you want to know where the leak sensor is on your Electrolux dishwasher, model# EDW5500DSS. Typically the leak sensor will be located underneath the tub area. There are no diagrams that show exactly where the sensor is located. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and will be able to best assist. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux 24 in. EDW5500DSS Stainless...
How to fix error code leak detected on Electrolux EIDW5905JS0A?
I understand you have an error code of a leak detected on your Electrolux dishwasher, model# EIDW5905JS0A. I also see that your drain was clogged to start and after you cleared the clog was when the error came up. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux Dishwashers
Electrolux washer e 13
Water leak in tub or leak in air bell is what the code means if you do not see water leaking and you can not find a air leak in the hose or air bell test the pressure switch if it test fine then replace the control board
Feb 12, 2014 | Electrolux Washing Machines
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Water dispenser leak all the time how can i fix it?
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
New unit never used found the water filter cracked
THE FILTER HOUSING MAY HAVE FROZE AND BROKE. MAY HAVE FROZE ON TIME IN SHIPPING. CALL ELECTROLUX THEY WILL SEND YOU THE PART AND A TECHNICIAN TO FIX IT. SO IT COULD BE REPAIRED IN ONE TRIP.
Apr 24, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Jan 25, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux ER6641T Compact Refrigerator Logo
37 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
