Question about Vacuums
My Electrolux el8807a precision upright vacuum is making an awful noise when I turn it on. Any possible causes?
I believe it to be a problem with the motor.
    New Friend:
  • 29 Answers
Your vacuum might have a full of dust reservoir. Empty it and it will become quiet again, since the vacuum motor will not be overcharged with clogged dust.
Posted on May 07, 2014
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
What does yellow exclamation point light mean
YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
Precision model blockage
No solution but we seem to have the same problem it is as if the valve isn't working. Please don't tell me to check for blockages.
Feb 24, 2014 | Electrolux EL8807A Precision BrushRoll...
Wand has no suction
had same problem, tried for two days to figure it out. husband figured out that at the bottom of the 'cup' where the wand sits is a round protrusion in the middle--that is your answer, that is what controls the valve. he pushed down on it with a tool, we actually had a small rock in the bottom of the cup preventing the plunger from working. now we know for next time. obviously out of warranty and did not want to buy a new vacuum.
Feb 22, 2014 | Electrolux EL8807A Precision BrushRoll...
I have an issue with an Electrolux Precision EL8802 - I can't figure out how to access the belt. I have removed the bottom dust cover and roller, but the belt isn't visible and it's not apparent how you...
There is no belt. The brush is direct drive by a seperate motor. There is a motor reset switch that you use if the brush is not turning. If that does not fix the problem, you have to take the unit in for service http://manuals.electroluxusa.com/prodinfo_pdf/Edison/86668R4en.pdf
Feb 02, 2014 | Electrolux EL8807A Precision BrushRoll...
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
The brush is not turning and a red light is on
It could be that the brush motor just needs to be reset. You should find a button near the brushroll cleaner step lever.
Nov 25, 2013 | Electrolux EL8807A Precision Brushroll...
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
Electrolux EL8807A Precision Brushroll Clean Bagless Upright Vacuum It has no succion with the handle
If it's an upright, the suction occurs at the base, where the rollers are. Can you explain in more detail what you are having a problem with?
Oct 18, 2013 | Vacuums
The roller wont roll
take it apart and clean the crud out of it, re-assemble and NEW drive belt while you are at it!
Sep 14, 2013 | Electrolux EL8807A Precision BrushRoll...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
