If their are two negative numbers in a multi step equations i add or subtract to undo
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
That depends on what you're trying to undo. If the last thing you did was add, then you subtract to undo. If the last thing you did was subtract, then you add to undo.
Posted on May 07, 2014
How do I solve (3x-2y)2(3xy-3)
First, we will find y in terms of x. We will use the first equation to determine this.
4x+2y=2
We can subtract 4x from both sides:
2y=2-4x
And then divide both sides of the equation by two:
y=1-2x
Since we now have y in terms of x, we can substitute this into our second equation.
-3x-y=-3
-3x-(1-2x)=-3
Then, we can distribute the minus sign
-3x-1+2x=-3
-x-1=-3
Next, we can add 1 to both sides of the equation.
-x=-2
Finally, we divide both sides by negative one to isolate x.
x=2
Now that we have x's value, we can find y's value.
The first thing that we determined is:
y=1-2x
We can substitute in the value of x to this equation.
y=1-2x
plot-formula.mpl?expression=y=1-2%2a2&x=0003
y=1-4
y=-3
Therefore, we now have the values of both variables.
x=2
y=-3
Jan 13, 2015 | SoftMath Algebrator - Algebra Homework...
What is the steps of this multi step equations
A-2+3=-2
Rule when solving equations is to do to one side what you do to the other.
We want A to be by itself.
To get rid of -2 on the left side, we must add 2 to both sides.
A-2+3+2 =-2+2
A+3 = 0
To get rid of the 3 on the left, we must subtract 3 from both sides.
A+3-3 = 0 - 3
A = -3
To check if we did it correctly, put A = -3 in the initial equation and see if the left side is equal to the right side.
Good luck.
Paul
Oct 16, 2014 | Office Equipment & Supplies
Complex matrix
Is it complex or matrix? You can have only one mode at a time.What kind of equations? The solve function uses real-valued equations.
Complex numbers: You can add, subtract, multiply and divide. You can convert a number from rectangular to polar forms and vice-versa; you can calculate the absolute value of a complex number, or a conjugate.
All the operations are done in the Mode CMPLX.
Feb 04, 2014 | Casio FX991MS Scientific Calculator
825 - (659 - (410 - 360) x 684)= ?
This is a classic use of the old PEMDAS rule. The order of operation goes by Parenthesis, Exponents, Multiplication/Division, Addition/Subtration. Take it step by step to avoid getting mixed up.
The first operation done is (410-360) which = 50. New Equation: 825 - (659 - 50 x 684) = ? The second operation done is 50 * 684 which = 34200 New Equation: 825 - (659 - 34200) = ? The third operation done is 659 - 34200 which = -33541 New Equation: 825 - (-33541) = 825 + 33541 = ? it becomes +33541 because subtracting a negative is the same as adding the positive. The final operation done is 825 + 33541 which = 34366 Your Final Solution Is:
825 - (659 - (410 - 360) * 684) = 34366
May 07, 2011 | Texas Instruments TI-83 Plus Calculator
I want to do subtraction. But when I enter the "
There's a negative button and a minus button. I think you're accidently pressing the negative button. The actual subtraction button is the red "-" button above the "+" button. I hope this helps, but if all else fails, you can always add a negative!
Apr 16, 2011 | Canon P23-DH Calculator
How would you do negative exponents for scientific notation? example: (6.0 x 10^6)(2.0 x 10^4), I am required to use the EE button for my exponents since it's a scientific notation equation but I do not...
Use the (-) key for negative numbers (not just exponents) instead of the - key. The - is to subtract one value from another, (-) is to input a negative value.
Sep 09, 2010 | Texas Instruments TI-30XA Calculator
What does MC,MR,M-,M+ on the calculator mean and do?
MR is Memory Recall
MC is Memory Clear
M+ is Memory add
M- is Memory subtract
These are used to add and subtract the answers to multi-step equations so you can do the small steps with the calculator, then store, change or recall the total as needed. You might add a long string of numbers in groups this way. Or you can do all operations in one parenthesis, then just store the total of each.
A good problem to illustrate this would be : (123 x 3) + (55 - 24) + (10^2) - (7 x 8) = ???
Using MR, M+ and M-, you can do each one as a group, and only store the answers. 123 x 3 = 369 so M+ to put 369 in memory. Clear it from the calculator. 55 - 24 = 31, so M+ to put this in memory and add to the 369 already there. Clear it from the calculator. 10^2 = 100, so M+ this to memory also to add it. Clear it from the calculator. 7 x 8 = 56 so M- this to SUBTRACT it from memory. Clear it from the calculator if desired. Now, when you then hit MR, you will get the total of all of these small equations in parenthesis -- 444.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2009 | Office Equipment & Supplies
Find the value of the variable ''x'' 6x+6=4x+12
6x+6=4x+12
Since 4x contains the variable to solve for, move it to the left-hand side of the equation by subtracting 4x from both sides.
6x+6-4x=12
Since 6x and -4x are like terms, add -4x to 6x to get 2x.
2x+6=12
Since 6 does not contain the variable to solve for, move it to the right-hand side of the equation by subtracting 6 from both sides.
2x=-6+12
Add 12 to -6 to get 6.
2x=6
Divide each term in the equation by 2.
(2x)/(2)=(6)/(2)
Simplify the left-hand side of the equation by canceling the common factors.
x=(6)/(2)
Simplify the right-hand side of the equation by simplifying each term.
x=3
Good Luck
Sep 10, 2009 | Audio Players & Recorders
Tring to subtract
With an adding machine, which is what this is, you enter the number followed by the + or -. If you wanted to add 10+20, you would enter 10 then + then 20 then +. This would show your answer. If you are using the printer and you wish to see the final answer on the paper, hit the * key and your answer will print.
If you are subtracting, let's say 100-40, you would enter 100 then + then 40 then - then *. Adding machines expect you to enter long strings of numbers to total. You may have both positive and negative numbers. So, you always enter the number first followed by either positive + or negative -.
You might have 100 + 25 - 37 - 1 + 50. For that enter:
100+25+37-1-50+ then *
Different than a calculator but the same for all "adding machines". This machine should really be called an adding machine since that is the kind of input it is looking for.
Jan 13, 2009 | Canon P23-DHV Calculator
How do i make subtraction, additions and divisions using excell
Put the figure which you have to multiply in cell A1, Put the figure in cell A2 by which you have to multiply by, type =A1*A2 in cell A3. You will get the right answer.
You may substract, multiply or add by this method by appropriate mark in cell A3 in between A1 and A2.
npbhoge@rediff.com
Jul 29, 2008 | Microsoft Excel for PC
Computers & Internet Logo
David Payne
David Payne
