Question about Dryers
It fell and every time it unplug i t go o 12:00
  • Dryers Master
  • 3,368 Answers
What are you asking. Normally dryers do not fall there feet are already on the floor.
Posted on Jun 07, 2014
What are the best aviation subjects to start an aviation website with?
Really depends who you think your audience is. Lay people may just want to know how a plane flys or why certain things happen on commercial flights. Pilots may want to learn about skills/ratings they havent acquired yet, recent incidents.
May 20, 2017 | Aircrafts
How many btus per sq ft?
12,00 per 400 sq.ft.
Sep 12, 2015 | Heating & Cooling
Mitsubishi dion.the vehicle can't start
is many things which can result in not starting.
1) check if ur starter motor cranks if it does ,check for spark.
2)if the starter doesnt check your battery state by using a multimeter take the readings if is 12,00 volts or more is good
3)check your battery terminals contacts against the battery poles if bad use hot water pour over them but extra careful is needed because some of electronic component hates water
Dec 01, 2013 | Cars & Trucks
Can you translate the model number please
I cant tell you the date it was made, only from the serial number. But the 036 tells me it is a 3 ton unit. There is 12,00 btu per ton of cooling, so on your carrier, 3x12=36, which will be the 036. That's about all I can give you on the number.
Shastalaker7
Nov 21, 2011 | Carrier 38CKC036 Air Conditioner
My Utillity heater fell over and now wont siwtch on, the power light isn't on either. I have checked the fuse but it is fine. Does this thing have a reset inside??
Try unplugging it for 30 minutes. That should give it time to reset itself. While unplugged, hold it upright by the handle and bump it gently and squarely on the floor. The tip over switch may be stuck.
Hope that solves your problem.
Mar 07, 2011 | Honeywell HZ2110 Utility Heater
I installed Printmaster 2011 platinum on my pc. Everything went well until I tried to print my project. I have an error message everytime that says: Printmaster 2011 Platinum 3.0.70 encountered the...
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Oct 22, 2010 | Broderbund PrintMaster Platinum
How do i reconnect capacitor cbb65a-1 from my haier esa3125 12,00
The wires usually just have connectors that push on/pull off. Some capacitors run the fan and the compressor and have 3 different terminals. It is very important to make sure the wires get put back on the right terminals on this type. You can find a capacitor at a local heating and air store.
May 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
I have Windows 7 and just installed PrintMaster 2.0 Platinum. I cannot print anything. here is the error message. PrintMaster 2.0 Platinum encountered the following error: java.lang.NumberFormatException:...
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Dec 21, 2009 | Broderbund PrintMaster Platinum
Interior drum one of the three turner shelves fell off into the drum during the cycle - help
Unplug the dryer
Unplug the dryer
UNPLUG THE DRYER
remove the top and remove the front panel look for the screw(s) that fell out at the inside under the drum use a flashlight and a magnetic pick up tool screw the baffle back in replace front and top.
Sep 03, 2009 | Maytag Dryers
Maytag air conditoner
Unless you can see if the fan is hitting something, you can't. You will need to take it to a repair shop. Sorry.
Jun 09, 2008 | Heating & Cooling
Dryers Logo
19 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
