Question about Fellowes Office Equipment & Supplies
W11C shredder My Fellowes W11C shredder stopped working suddenly What can I do to get it working?
  • 3 Answers
Have you read through the manual for the shredder?
http://assets.fellowes.com/manuals/W11C%20Manual_1L_2008.pdf
Posted on May 13, 2014
5 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: was shredding papers and unit stopped,and will not
Make sure you use a can of compressed air and cotton swabs to cean the entrance and exit sensors.
Posted on Jun 11, 2009
SOURCE: Our Fellowes shredder (#W11C) will
I have that problem as well after a few months of normal use
Posted on Aug 23, 2009
HansPP
  • 2510 Answers
SOURCE: I have a fellowes shredder
Check if the power cable was not damaged or pulled out of the connection during the mishap.
Posted on Jun 08, 2011
  • 147 Answers
SOURCE: Fellowes W11C shredder is brand
Did the shredder work at all? These shredders are only rated to run for 5 minutes at a time, then it needs to cool (this could take a 1/2 hour).
Troubleshooting tips:
• Make sure shredder is plugged in and switch is in automatic [I] position. • If paper appears to be jammed. Follow instructions under Operation. • Check shredder head position. Follow instructions under Set-Up. • Wait 20 minutes for shredder to cool down before trying again.
Hope this helps.
Posted on Jul 11, 2011
Where is the fuse in the fellowes w11c?
There probably isn't a fuse. Or it's a non-replaceable one.
They suggest you allow it to cool for 20 minutes, when it becomes overheated it's supposed to shut down. Then in the case of a paper jam, try reverse, if that doesn't work, try forward again.
Aug 02, 2016 | Fellowes Powershred W11C Shredder 120V,...
My Shredder W11C stopped working suddenly both forward and backwar. The power source is O K.
if you can hear the motor working but the paper won't pull in and shred then you broke a tooth on the plastic gear. This happens when you try to shred too much at one time. It happened to me but I couldn't find a plastic gear or the company to replace the gear. I liked the machine so I made my own tooth with DEVCON home plastic welder. With a little ingenuity and some tools you could try to fix it. Or like someone said buy a new shredder
May 07, 2014 | Fellowes Office Equipment & Supplies
Suddenly stopped. Power source is good.p Had been working ed. Does not go forward nor backward. Power source is goog.
It could be there is still some material in the cutting wheels. We have had this happen to our shredder a few times, do your best to get stuck materials free.
Good Luck
May 07, 2014 | Fellowes Powershred Personal W11C Shredder...
Fellowes W11C: will only run in reverse. Where are the sensors located?
There is a switch to put it in reverse. This is not a sensor problem. All the sensor does is detect something in the slot.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Fellowes W11C Confetti-Cut Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Machine won't come on . I think the sensors need to be cleaned
Try going to OfficeMax and buy some lubrication paper that is made to run through your machine. I had the same problem. It was like there was a short in the shredder. Bought the lubricating paper and it worked the first time. No problems since. Good luck!!
Dec 07, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Was shredding papers and unit stopped,and will not take anymore papers,but it will still go in reverse Fellowes model w11c
Jun 11, 2009 | Fellowes W11C Confetti-Cut Shredder
126 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
