Question about Tivax LSS-505 Model Michley Lil Sew & Sew Portable Sewing Machine, Double thread, double speed, Featuring 8 built-in stitch pattterns, Forward and reverse sewing, Automatic thread rewind, Sews sleeves, Drawer included, Use hand switch or foot pedal to star
Jamming Lss505 sewing machine
Needle or bobbin not sure which keeps jamming when i start to sew
    Novelist:
  • 268 Answers
Hold the end of the top and bobbin threads together behind the presser foot while you take the first 2-3 stitches in a seam. If this is a new machine that you can return, consider doing so -- these little critters never last long.
Posted on May 22, 2014
ORDER BOBBIN CASE FOR LSS505 sINGER pIXIE pLUS
Take one of your bobbins to the local fabric store, Singer dealer, or sewing machine repair shop and compare with what they have in stock. Be sure the bobbins you buy are metal as your machine will not work with plastic bobbins.
Jan 08, 2016 | Singer Sewing Machines
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
The bobbin keeps getting jamed
rethread the machine top & bobbin
make sure the bobbin is not fully wound, usually wind the bobbin
3/4 full, when I was sewing last night & rewound the bobbin & I wound
it to full & it jammed twice on me.
make sure the top thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area
Aug 08, 2012 | Singer Pixie Plus Sewing Machine
Elna 9000 bobbin problem
try changing the needle,,make sure the needle & thread & fabric are correct for each other
make sure the bobbin is turned the right way
it's also possible that when the needle gets jammed or broken that the machine can become out of time
and would have to be retimed at a sewing machine shop
Apr 01, 2012 | Elna Sewing Machines
I HAVE A 1418 MACHINE WHITES.. MY NEEDLE KEEPS GETTIN CAUGHT IN SOMETHING IN THE BOBBIN AND IT JAMS. WHAT AM I TO DO
put in a new needle
clean under the needle plate & bobbin area for loose threads & lint
make sure the bobbin is not warped
try a different thread
of the problem still happens, then it needs to be serviced
Aug 05, 2011 | White Sewing 1418 Mechanical Sewing...
The needle keeps hitting the bobbin holder, it has actually nicked it. I cannot sew, the bobbin thread just jams up in a bundle and the machine jams
Check to make sure the needle is up all the way into the clamp. If the bobbin case now has sharp edges from the impact. polish away the sharpness with an emery board or simular. Once a needle is hit it canot be used again so always use a fresh needle.
Dec 12, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
Bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Aug 07, 2008 | Sewing Machines
Tivax LSS-505 Model Michley Lil Sew & Sew Portable Sewing Machine, Double thread, double speed, Featuring 8 built-in stitch pattterns, Forward and reverse sewing, Automatic thread rewind, Sews sleeves, Drawer included, Use hand switch or foot pedal to star Logo
132 people viewed this question
Top Tivax Crafts & Hobbies Experts
Debbie
Carolyn Rogers
Carolyn Rogers
thinksewfast
Are you a Tivax Craft and Hobby Expert? Answer questions, earn points and help others
