Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Similar problem, the door will not open very much at all.
I also think it may be related to the temperature because it worked again in the early morning when it was cooler. I will try to adjust the spring tension also to see if that helps.
    President:
  • 3,197 Answers
You need to remove the cover and look at the drive gear. It is white nylon and is just in front of the motor. May be stripped. Also take a close look at the door springs. One could be broken.
Posted on Jun 22, 2009
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Craftsman garage door opener problem
If you have eliminated the obstruction sensor, I would suggest a few things. Is the door spring set at the proper tension - usually check by releasing the door safety and manually closing/opening the door. It should balance about halfway up/down. Openers have limit switches for travel, if one is incorrectly positioned or faulty, it can cause similar issues. Openers have torque limit controls, if the motor thinks it is working too hard it will stop. Is the door greased and moving freely when you manually tested it for the spring tension? Are the gear sprockets firm and greased?
Sep 22, 2017 | managemylife.com Home Security
I have the one with frezzer on bottom and french doors fan makes loud noise louder some days then others open doors it stops close them back and it starts again my modle does not have an ice or water...
refrigerator (commonly called a "fridge") is a cooling apparatus. The common household appliance comprises a thermally insulated compartment and a heat pump-chemical or mechanical means-to transfer heat from it to the external environment (i.e., the room in which it is located), cooling the contents to a temperature below ambient. Cooling is a popular food storage technique in developed countries and works by decreasing the reproduction rate of bacteria. The device is thus used to reduce the rate of spoilage of foodstuffs. A refrigerator maintains a temperature a few degrees above the freezing point of water. Optimum temperature range for perishable food storage is 3 to 5 °C (37 to 41 °F).[1] A similar device which maintains a temperature below the freezing point of water is called a "freezer".
The refrigerator is a relatively modern invention among kitchen appliances. It replaced the icebox, which had been a common household appliance for almost a century and a half prior. For this reason, a refrigerator is sometimes referred to as an "icebox
Jan 16, 2011 | Samsung Refrigerators
We have a Kenmore Elite 79577554600 Refrigerator. The temperature display is freaking out. The numbers keep changing, lights flashing on and off, temperature counting down from 44.
It is running in "store-demo" mode. Fancy light-show, and the compressor turns off (bad!)
Hold down the right-most two buttons (Ice and refrigerator temp) for about 5 seconds. I think the right-door needs to be open for this to work, but not sure.
This will activate the fridge once again.
Dec 24, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Hello, I bought a Whirpool refrigerator about a year ago and it has worked reasonably well. Since this summer, which has been hot and humid, every time I open or close the freezer door, the rubber along...
It's possible that it could be from the humidity.. If it is the rubber itself making the noise, try applying some vaseline to the face of the gasket on the hinge edge of the door. The factory lubricates the gaskets in a similar manner and it is common for it to get cleaned off by the consumer. It is good practice to keep both doors lubricated the same way to prevent the gaskets from getting stretched at the corners as this is a pinch point..
Good luck with this and let me know if you have any other questions or problems!!
Aug 14, 2010 | Whirlpool Refrigerators
AC blows hot air on the driver side and cold air on the passenger side
You may have a bad temperature door actuator motor on the drivers side. The actuator is what moves the temperature blend door and when it fails it usually moves the door all the way to the "hot" position. Sometimes if you shut the vehicle off for a bit then restart it the system will work fine for a while then the actuator will again swing the door all the way open or shut. I've replaced several of these actuators [both drivers side and passenger side] for similar problems.
Jul 08, 2010 | 2005 Chevrolet Silverado
Problem with Daewoo Nubira doors
try spraying wd40 or similar into the laches, " the ones that lock the door, looks like you ran out of grease and that's why they get stuck, little lubricant " oil " will keep moisture away preventing it from freezing again
Jun 01, 2008 | 2001 Daewoo Nubira
Automatic Garage door reverses and automatically opens after closing
I can't believe it! My opener works fine a 10 degrees and above but below 10 degrees it would go down a little ways stop and go back with the light flashing. I checked the electric eye and found it would go out of alignment when the temp drop. Who knew!
I made the adjustment and it now works fine.
Jan 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
63 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
