Question about Boating
How do i know if my yamaha 40 autolube work - Boating
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 36 Answers
These motors only have a sensor for the oil level in the tank so there is no warning system for the actual oil pump. They will have three separate oil lines running from the oil pump to a hose barb for each cylinder on the intake manifold (right behind the carbs). You can pull each line off while the motor is running to make sure the pump is working. On idle there will be very little flow so don't be alarmed.
Posted on Jun 22, 2014
Can a loose/cracked autolube delivery hose cause vacuum leak on 1976 yamaha dt125 with autolube? Also, is it necessary for rubber crankcase holder for the oil & delivery hoses to be completely sealed?
Hi, Tod you may have a carburetor issue, replace your autolube line and not sure about the hose grommet but you can smear a light film of vaseline all around the sealing edges, start the engine and watch what happens if it gets sucked in or blown out seal as necessary with silicone otherwise the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/37995-dt175-running-on-choke-only
Vintage Enduro Discussions Forums
What could be wrong if bike will only run on choke
YAMAHA DT 125 SERVICE Motorcycle Repair MANUAL 1988 2002 Download Manuals...
Aug 06, 2016 | Yamaha Motorcycles
How do i know if 40 yamaha autolube work
Good Morning Koos,
Take One Caddy Tank Of Fuel Add 500 Mls Outboard Oil.
Mark Oil Level Of Oil In Auto Lube Tank Use The Outboard WIth The Pre Mixed Fuel Once You Have Completed The Tank Of Fuel,You Will Then Check Your Lube Tank If It Is Working Correctly It Will Also Have Used Aprox 500 Mls Oil Probably a Little Less ,If This Is True Then It Is Working Correctly And You Can Revert To Fuel Only.
Hope This Helps ,Cheers Gordon
May 07, 2014 | Boating
Oil pump adjustment
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/23188-dt125r-dtr-dt125-oil-pump-problem
Autolube Settings On My Yamaha DT125RE
http://www.motogelnar.cz/manual/YAMAHA/DT125X_RE-05-Service_Manual.pdf
OEM parts for Yamaha
http://www.dt125.cz/download/Owners_Manual-DT125X_RE.pdf
May 02, 2014 | Yamaha DT 125 R Motorcycles
Troubleshoot 1978 Yamaha DT175 oil injection pump
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
TWO STROKE AUTOLUBE OIL PUMPS
1978 DT 175 Oil Injection
1992 2002 YAMAHA DT175 FULL SERVICE REPAIR MANUAL INSTANT DOWNLOAD...
http://mybikemanuals.com/yamaha/yamaha-dt
Nov 19, 2013 | Yamaha Motorcycles
How to adjust the oil pump of Yamaha DT125R?
Hi, James sorry you can't find the first and best tool you ever bought for your Yamaha despair, not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Setting Pump Oil Yamaha Autolube
Aug 17, 2013 | Yamaha DT 125 R Motorcycles
Oil pump adjustment
Hi, James for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
I have just picked up a 1967 yamaha yl2 100cc bike, can someone tell me what grade of oil to run in the autolube system please?? Thanks
On a machine as old as this any present-day 2-stroke oil will outperform the original manufacturers specification.
Apr 30, 2011 | Yamaha RD 250 Motorcycles
Problem with autolube pipe 1999 yamaha dt 125 air cooled
it will rev cause it is sucking air where the oil pipe used to be. the tube will be close to the rubber intake, if not on the intake itself
Feb 12, 2010 | 2000 Yamaha DT 125 R
2007 Yamaha DT 125 oil pump settings
Hi, Evdbank for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha DT125RE 2005 Service Manual
YAMAHA DT125R Owner Manual
Aug 28, 2009 | 2006 Yamaha DT 125 RE
I have a 1978 Yamaha DT175E. It is runnig rough like runnig rich but idles ok put on a new carb checked autolube oil pump and timiing,found that runs better when air box is not conected to carb but still...
Check the choke to see it is not stuck on.
Something is causing the bike to run rich as you said.
Make sure the throttle slide isn't stuck and is working ok.
Try a smaller size jet.
Jun 12, 2009 | 1974 Yamaha DT 360
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
