Question about Canon Office Equipment & Supplies
How do to reset canon ir 2420
I have error 000805-0000
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
Canon 2420
replace the imaging film,get a tech to do it
May 27, 2015 | Canon Office Equipment & Supplies
Code Error on Ir 2420 l display **E000003-0000 what can i do please solve this...
dear
pl. do check the fixing film assy. heater strip contact points. if corrosion clean/replace it.
Check the DC card.
Also check the supply voltage at the machine input.
Thanks.
Dec 04, 2014 | Canon Office Equipment & Supplies
Update firmware to ir 2420
BIOS MODE wait updating F/W for canon ir 2420
May 26, 2014 | Canon ImageCLASS MF4370dn Laser All-in-One...
E000808 0000
Please What can the solve of Problem Restart the machine if problem persists call service rep. error message : E000808-0000 model canon ir 2420L
Nov 30, 2013 | Computers & Internet
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
56 people viewed this question
old marine
old marine
