Question about Kenmore 30" Freestanding Electric Range Model 9230
Broiler will not turn off
Kenmore electric range, model # 911. Broiler element will not shut off unless circuit breaker is shut off. no indicator light on panel is lit and turning the circuit breaker back on does not solve the problem,
catriver
  • 878 Answers
SOURCE: oven element
model T, either you have a stuck or shorted broil keypad or the relay on the board is welded closed. Try this, remove the back panel behind the control panel. Make sure the breaker is off to the range. Unplug the keypad ribbon cable to the main board. Power the unit back up. You should get an error code. Now if the broiler still comes on you know you have a welded broiler relay on the board. If the broiler doesn't come on..it's the keypad. Catriver.
Posted on Sep 20, 2007
SOURCE: Kenmore electric range
You need a new mother-board.
I had the same issue, it overheated my kitchen in a matter of minutes. If I didn't turn off the circuit-breaker, I probably would have had a fire - the heat being emitted was intense. The cost is running around $300. with tax and delivery. I'm not sure if I want to repair or purchase a new oven.
Posted on Sep 25, 2008
  • 81 Answers
SOURCE: Broiler Stuck On - Want to Disconnect
Yes, you can remove the broiler element. Usually they are just plug in after you unseat them If there are wire leads, you must follow them back and remove them from their terminal. If you follow the lead back to the terminal, you may just remove them with a pair of pliers and pull the burner out.
Posted on Apr 25, 2009
buffalonyman
  • 1865 Answers
SOURCE: Broiler turned on by itself and won't turn off
The contacts on the switch are welded close, and need to be replaced
Posted on May 26, 2009
  • 464 Answers
SOURCE: Kenmore Oven and Broiler stopped working
My first suggestion is to remove the broil and the bake elements from the oven (unplug it or shut off the breaker) and test them with a meter on the OHM setting and see if you have continuity. You can't always tell if they are blown just by looking at them. Secondly, if they both check out alright, I would be looking at the ERC - electronic clock - you have a burnt relay in which case you will need a new one. Depending on where you are you may be able to find a place where it can be rebuilt for about 1/2 the cost of a new one. Hope this helps you.
Posted on Jan 26, 2010
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Oven element
Sep 19, 2007 | Kenmore 92002 / 92004 Kitchen Range
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
Jan 26, 2010 | Kenmore 92680 / 92681 / 92682 Electric...
Broiler does not work!
rEPLACE BROILER ELEMENT. LOOK INSIDE OVEN, FIND SCREWS ATTACHING ELEMENT TO BACK PANEL. TURN OFF POWER. REMOVE SCREWS, SLIP OFF WIRES.
Oct 21, 2009 | Kitchen Ranges
Kenmore range bake element doesn't work
check that the wiring is not bad and every thing is conected
Jun 04, 2009 | Kenmore 95922 / 95924 / 95929 Electric...
Apr 25, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 30" Freestanding Electric Range Model 9230 Logo
24 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
