Question about AT&T TL7600 Wireless Headset
How do i pair the tl7600 to a new base
I just replaced my phone how do i pair the tl7600 to the new base
2 Suggested Answers
mosner
SOURCE: how do I put the
Here is the solution to deregister the TL7600 without the base:
Push these buttons in the following order:
  • vol+
  • mute
  • vol-
  • mute
  • vol+
  • vol-
  • mute
Posted on Oct 18, 2013
How to pair AT&T TL7600 with AT&T 86103 Deskphone
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109 !!!
If you have been going nuts on how to pair TL7600 with TL86103 or TL86109 Deskphone, here is a detailed answer.
First of all TL7600 does not need pairing, it is a passive wireless i.e it remains in hunt mode till a deskphone actually pairs with it.
First things first - Charge the Dect Headset TL7600 for 1-2 hours. Press the On/Off button once and you will see a blue/red light that will keep blinking every 2-3 seconds. This shows that the headset is unregistered with the Deskphone. When the headset becomes properly paired and placed on the charger, it will show steady blue light.
Okie, now to registering the headset.
a) First, lets reset the TL7600 just incase it was paired to another phone. Even if it is not, lets just do a reset to avoid some problem.
Push these buttons in the following order one by one :
vol+mutevol-mutevol+vol-mute
b) Go to the TL86103 and keep TL7600 very close to it. Lift off the TL7600 off the charger and then put it back in.
c) Press "MENU" on telephone mode with phone handset on the phone and the phone in Idle Mode.
c) Scroll to "Settings" and then scroll to "Register"
d) All this while, the TL7600 should be on the charger. If you remove it from the charger, it will not register.
e) Within 90 seconds to 2 minutes, the headset will be registered and you will see the handset will be assigned a name on the phone.
f) Pick up the headset, switch it on and you will hear a dial tone.
g) If this doesnt work, try to first press hold for 10 seconds till it says "Unregister All Devices', Click Yes and go through the process again.
j) If you want to know how to make a call, please note that the call will have to made first on the deskphone, then switch on the headset and there you go. Either lift the reciever and make a call or press Speaker and make a call and then switch on the headset, put the deskphone handset down or switch off the speaker and your TL7600 will be connected.
*** For TL86106, everything is same till (b). After that, press HOLD Button on the phone for 4-5 seconds till you see "Registering". Within 90 seconds to 2 minutes, the device will register the TL7600.pair-t-tl7600-t-86103-deskphone-wg3ndzwv23znm50ophchmy55-3-4.jpg
Dec 31, 2015 | AT&T Lands Phones
Pairing at&t to uniden
Please note we do not test our products with third party accessories/products.
Jun 22, 2015 | Uniden Radio Communications
How do I put TL7600 in pairing mode
Watch this video and follow the instructions
Apr 30, 2014 | AT&T TL7600 Wireless Headset
Won't hold a dial tone go new batteries still a problem
Maybe trying to pair the handset with the base station will solve your problem. Look in the manual how the pairing procedure is done for your phone.
If the pairing procedure is done, and the handset finds the base station and there's stil no dial tone, check if the cable from the telephone line is plugged in the base station of the phone and check if the other side of the cable is plugged in the wall phone outlet.
I hope this will solve your problem.
Feb 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i pairing a tl7600
Nov 07, 2013 | AT&T TL7600 Wireless Headset
TL7600 Headset will not pair with TL8802 base
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109/TL88002 !!!
*** FOR TL86103, do the below (See below for other models)
FOR TL86106, 86109 and 88002, do the below steps.
Aug 06, 2013 | AT&T TL7600 Wireless Headset
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
I can not use the handset. I can use the speakerphone. I put new batteries in the handset and the bottom of the phone. When I pick up the handset I do not get a dial tone, it squeakes or beeps.
You need to pair the handset to the base unit, hopefully you still have the manual. Because you didn't give a brand/model I can not give directions on how to pair the handset to the base unit.
There should be a menu button located on the base unit, just push it until pairing (or something like this) shows and you should be able to complete the pairing operation.
Hopefully this will head you in the right direction.
Mar 06, 2011 | Cell Phones
How do I put the TL7600 att headset into pairing mode?
  • vol+
  • mute
  • vol-
  • mute
  • vol+
  • vol-
  • mute
Oct 08, 2010 | AT&T TL7600 Wireless Headset
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
AT&T TL7600 Wireless Headset Logo
55 people viewed this question
Top AT&T Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an AT&T Radio Communication Expert? Answer questions, earn points and help others
