Question about LG 7.3 cu. ft. Electric Dryer - DLE2301
Does not stop spinning unless I open the door
When I open microwave oven door . close the door again light comes on an plate spins an wont stop unless I unplug it
Inside the door latch, is a safety feature, that prevents the microwave from operating unless the door is closed. This feature can easily become faulty, or even come with the fault already causing the microwave to constantly operate whenever the door is closed.
Microwaves can be very dangerous in regard to holding HEAPS of voltage within the unit. I recommend getting yourself a new microwave, as attempting repairs on any of the modern units can, more often than not, be far more costly then the price of a new one.
Hope this helps.
Apr 14, 2014 | Hamilton Beach Beach 87108 Microwave Oven
Dryer keeps running
An IC controller is deffective or can be converted into manual since it stop when you open the door, but only the technician can do this.
Feb 01, 2014 | LG Washing Machines
Dosen't spin unless i open and then close the lid.
Possible there could be some loose connections on the panel board or the controller unit circuit which gets activated when the door is shut. Try to tap instead of opening the door to confirm a loose joint. If not it is related to a RESET fault within the controller , please check the door switch and connections to the controller.
Dec 31, 2012 | Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I have a GE washer which the agitator and tub do not spin. I can turn both freely by hand. The belt is in tact. During the cycle, the motor just osillates a minute amount in both the clock and counter...
it might be the safety switch under the door.
it is a switch that will not allow the spin cycle to spin unless the door is closed - like when you look in your washer while its spinning and as soon as you open the door the spinning stops until you shut the door again.
if its damaged it will not allow the spin cycle to work.
try look under the lid.
costs around $3.00 put in with a screw driver good luck
aloha
Feb 13, 2011 | GE Washing Machines
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
Psp wont read the disc unless you hold the door shut w/o ...
If you dropped it, then the reader may be a little messed up. If the case around the disc is popped open a little bit, closing it all the way might stop the disc from spinning, resulting in not reading the disc. The only thing I recommend is to contact Customer Support on the Playstation website. They might be able to help you fix the problem or have you send it in. www.playstation.com
Apr 29, 2009 | Sony PlayStation Portable (PSP) Console
Lg front loader
You shouldnt be able to open the door when the washer has started and for a few minutes after it gets finished. Id=f you can then you have a faulty safety switch. The only way to open it when its started is to turn the dial to stop, and wait a few minutes until the lock turns off ( you will hear a click) then you can open the door, if its filled with water, then you shouldnt open it unless you want a puddle, you can put in on spin and get the water out before opening the door
Hope that helps
Aug 24, 2008 | LG Washing Machines
LG 7.3 cu. ft. Electric Dryer - DLE2301 Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
