Question about Sportcraft Sport & Outdoor - Others
Sportscraft dartboard model 78085
Dartboard height and distance
Gary, Standard height from the floor to the bulls eye on the dartboard is 68" inches (173 cm) and the distance from the front face of the board to the toe line should measure 93 1/4" (237cm).
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.pdc.tv/rules-of-darts
Darts Dartboards and Dart Supplies Dart Brokers
Dartboard setup
Apr 20, 2016 | Toys
Can a dart board dry out over time, or not?
No, it is very unlikely that a dartboard should dry out at all. If left in the rain or outside, it might fade and deteriorate, but it won't dry out. In the early 1900's dartboards were made from wood, which did dry out. But modern dartboards are made from fibers that prevent this from happening. Reference:
Where did the Dart Board originate from
Feb 27, 2015 | Sport & Outdoor - Others
What kind of power supply for my smartness electronic dartboard model #96229-022
I found one with the same part number with a fairly large display across the lower bottom. This one I found will turn on with a 12 volt dc 750mA power supply, it happened to be the first one I tried.
Mar 04, 2014 | Sportcraft Multiple Lighted Electronic...
Are electronic dartboards more expensive than bristle dartboards?
You will notice that most electronic boards are more costly because they offer a wider variety of options. When choosing to purchase an electronic dartboard you are getting more than one game, you are buying a product with several games built in one console.
Jul 26, 2012 | Sport & Outdoor - Others
What transformer will work on sportcraft electronic dartboard
The Sportcraft dartboard transformer that I have shows the following data:Model No: D9 - 10Input: 120V 60Hz 25WOutput: 9VDC 800mAHope that helps
Jan 22, 2012 | Sportcraft Multiple Lighted Electronic...
Sport & Outdoor - Others Logo
221 people viewed this question
Top Sportcraft Sport & Outdoor - Others Experts
Are you a Sportcraft Sport and Outdoor - Other Expert? Answer questions, earn points and help others
