My kenmore 80 top load series wont rinse top load wont rinse
My kenmore 80 series wont rinse everything else works but when its time to rinse i will here a click like some thing should be turning and realesing the water nothing happens ill hear a humm and it just stand still.
    Sergeant:
  • 212 Answers
Drain pump is trying to drain. maybe have something in pump
Posted on Jun 22, 2009
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
Washing machine Series 80 Kenmore wont drain water after it's RINSE cylce including the motor. It's like the TIMER stopped after the RINSE CYCLE. I think it's the timer.
does it drain after the wash cycle? if it does, then I don't think it's the timer. It uses the same contact there as for the rinse cycle. Do you hear the motor running as if it's trying to drain? If the motor is running, perhaps the pump itself is no good? Just a couple things to check. Hope it helps.
Joe
Sep 05, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
80 SERIES NOT SPINNING
It wont be the capacitor or the motor wouldnt work on the wash cycle. It could be the lid switch, & yes you could bypass the switch to prove if it is open circuit, you may even find a burned out wire to the switch. TURN THE POWER OFF FIRST THOUGH!!
Oct 22, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
