Question about Philips GoGear ViBE Digital Media Player
How turn of parental volum control on Philips GoGear Vibe?
SOURCE: Gogear Vibe is ''frozen''
I just reset it, and it works great. Need to keep it updated.
Posted on Jun 13, 2009
YourZEN
  • 820 Answers
SOURCE: Describe your philips GoGear Vibe model
Overview link for the GoGear Vibe SA1VBE04K/17:
http://www.consumer.philips.com/c/portable-video-player/gogear-vibe-4gb-sa1vbe04k_17/prd/us/
Selecting the support tab links to next site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1VBE04K/17&scy=US&slg=en
Select under Product support the required software & drivers.
Posted on Oct 29, 2009
hunter19_46m
  • 7482 Answers
SOURCE: How do you delete videos and photos from a Philips
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Good Luck, I hope this helps
Posted on Nov 28, 2009
SOURCE: philips gogear vibe your player is not connected.
How do I clear data (music, photos, etc.) that have been downloaded to my Phillips Go Gear Vibe MP3 ?
Posted on Dec 26, 2009
  • 16 Answers
SOURCE: how to fix power problem of GoGear Vibe 4G
UR MUM
Posted on Jun 06, 2010
What does file not supported mean on my gogear vibe and how do i change it
Your Philips GoGear Vibe supports these formats:
audio
  • MP3
  • PCM
  • ADPC
  • Audibl
  • WMA
video
  • SMV
audiobook format 4.
More support info:
Philips GoGear MP3 video player SA1VBE08K ViBE 8GB
Dec 16, 2013 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
GoGear Vibe 4gB Fullsound issue. Hi all. I have a minor problem with mi philips gogear vibe 4gb. If i play any song with the option Fullsound turned on, it turns off when the player jumps to the next...
This could be a feature which does not encourage the full sound option as it might drain off the battery in less time. Hence it is to be used only in cases where the need is necessary and so you need to manually select the song or skip before it selects by itself as the volume level can be retained.
Aug 31, 2011 | Philips GoGear ViBE Digital Media Player
I have a Phillips GoGear Vibe MP3 player. How do I turn it off??
I suspect all models of the GoGear Vibe work the same way. You turn on and off the unit by sliding and holding the switch on the side. This switch is on the opposite side from the volume controls. If you simply slide this power switch in the opposite direction, you can toggle the button lock on and off. (This locks every function except the volume control.) (Look for the power and padlock icons near the switch.)
Documentation for the Philips MP3 players should be available from their site. The SA1VBE04K/17 documentation is here: http://www.usa.philips.com/c/mp3-media-player/gogear-vibe-4gb-sa1vbe04k_17/prd/en/;jsessionid=2F114FC33AAEE23A73C9DE3200F8E54F.app101-drp1?t=support .
I hope this helps.
Cindy Wels
Aug 26, 2011 | Audio Players & Recorders
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
Where do I turn it on?
There is a slide rocker on the right side of the unit. If this does not work the units battery may be dead and would require a charge for at least a few hours.
Mar 02, 2011 | Philips GoGear ViBE Digital Media Player
My philips gogear vibe will not turn on. it is charged.
when i hold down the turn on button.it would show the philips lable then just shut off. can you help me please.
Jan 07, 2010 | Philips GoGear ViBE Digital Media Player
No volume
When entering "Vibe" player on the Global Site Map, next overview appears:
http://www.search.philips.com/search/search?q=Vibe&s=all&l=global&h=all&o=
See page 7 of the Vibe manual in pdf format:
http://www.p4c.philips.com/files/s/sa1vbe04k_02/sa1vbe04k_02_dfu_eng.pdf
Dec 14, 2009 | Philips GOGEAR SA6045 MP3 Player
Oct 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear ViBE  Digital Media Player Logo
16 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
