Question about Krups 230 Egg Express Egg Cooker
BUZZER DOES NOT WORK
MACHINE WORKS PERFECT BUT HAVE TO USE EXTERNAL TIMER, THE BUZZER DOES NOT SOUND AT ALL
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Kenmore out of balance buzzer
What is the model number?
Oct 17, 2012 | Washing Machines
I have a t3303. my external speakers suddenly stopped working. they work perfectly on my cd player and my headphones work perfectly in the headphone jack on hte tower?????
Check the settings for your speakers in the sound settings. It is possible that the settings have changed. It is also possible that the sound card has went bad in that port.
Jul 17, 2010 | E-Machines eMachines Desktop PC
I also have 98 neon with "door ajar" light and buzzer staying on but ONLY when all doors are closed. key doesnt evan have to be in ignition! also the dome light works perfect with the door and light switch...
sounds like their is a short in the wiring to the dome light and buzzer... i know you don't want to hear that... if it is grounded somewhere that is why it quits when you remove the bulb... possible wire caught behind the dash when you put it back together... if so that would cause the ground...
Mar 22, 2010 | 1998 Dodge Neon
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
Kenmore 70 series
Sounds like your push to start switch has went bad. When they short out, or cross contact the power continually shoots through it, and the buzzer contniues to make that "Were Under Attack" noise. If that doesnt seem to work, then its a small chance that the timer has went bad.
Jan 09, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer buzzer
Depending on the model some have a separate buzzer you can disconnect and tape off the leads to it. If it is an electronic timer you can muffle the sound by taking a piece of electrical tape and covering the whole on the small black speaker attached to the timer.
Dec 18, 2007 | Kenmore 98702 Stacked Washer/Dryer
Krups 230 Egg Express Egg Cooker Logo
118 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Henry  Thomas
Henry Thomas
Mike
ArcFlash
Level 1 Expert
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
