Question about Garden
What kind of oil and hydraulic fluid go in my viper zero turn mower?
Need to add fluids to mower and dont know what kind to get
  • 64 Answers
SOURCE: TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Posted on Aug 23, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I have a Grasshopper zero turn mower that uses
yes just reguler hydralic oil it wont hurt a thing. but dont use atf its for transmissions in vehicles
Posted on Oct 26, 2009
braintrust
  • 62 Answers
SOURCE: Snapper Yard cruiser zero turn hydro pumps
should be on dip stick other wise use 90 wght wont hurt anything
Posted on Oct 27, 2009
rwvanlue
  • 486 Answers
SOURCE: I need to know where to add hydraulic fluid in a
... should be between operators seat and 3rd link arm. A large nut/cap on top of the transmission cover, near the rockshaft of the 3-point hitch arms.
Posted on Nov 08, 2009
  • 8404 Answers
SOURCE: My mower lacks speed in forward. It works fine
Good question ... what kind is it ... should I guess? Some take 30 weight non detergent oil ... others take transmission fluid type F or GM or other "flavor" (specialty oil). Some fill under the seat others fill else where. Are you sure it is hydraulic? Have you looked for the fill tube? Do you have the instruction/owners manual anywhere? I would like to help you and maybe I have, inadvertently. Please don't put anything in until (1) you know what kind of fluid is suppose to be put in (2) you know it is low and requires additional fluid (3) don't operate it until you get the answers to (1) and (2). Is there a dealer for your unnamed make and model in your town? Have you called them? Maybe you should give them a call ...
If you have additional information to offer which will help me to help you solve your trouble, please post it. Thank you.
Thanks for visiting FixYa.com today.
Posted on Jun 06, 2011
Left hand drive handle hard to move forward
drain and replace your hydraulic steering system oil and replace the hydraulic filter then refill system
Jan 26, 2016 | Toro TimeCutter Zero Turn Lawn Mower...
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
The right side hydraulic drive motor on my husqvana cz 4817 zero turn mower is hesitating and making a groaning sound like a power steering pump sounds when it's low on fluid. Can I add hydraulic fluid to...
there should be a single reservoir for the main drive motor that supplies fluid under pressure to the drive motors at the wheels . Check that level and if ok then the problem will be in that drive motor and it may need repairs.
Aug 06, 2014 | Cars & Trucks
How to bleed hyrdro fluid line
aahh this is a zero turn model right? as when bleeding any hydraulic line NEVER take line completly off just loosten it till it Weeps fluid and don't get your skin any place close to escaping fluid (yes it will go right thru your outter layer of skin) anyways zero turns have a equalizing line that runs between the two control lever valves (right,left side) this is the ideal place to bleed trapped air and of course use extreeme caution with the blade deck as you'll be working right over it and remember even though the blades are dissengauged there still turning a bit , so they can get you!! i suggest open fitting enough to allow weep then close for a bit then open again do this several times to release trapped air ooh and don';t forget to top off hydraulic oil again with fresh fluid (don't reuse old oil )
May 31, 2014 | John Deere Garden
My mower lacks speed in forward. It works fine in reverse. Does it need hydraulic fluid? If so, how do I add it?
Jun 06, 2011 | Garden
Aug 30, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
