Question about Samsung RF220NCTAWW Whtie 21.6 Cu Ft French-Door Refrigerator Bottom Freezer, Energy Star
Where is the ice maker reset button of model RF220NCTA
Location of icemaker reset button
SOURCE: Samsung Ice Maker on Mdl RB215LASH
ice maker fill line frozen up
Posted on Apr 07, 2008
TJBENGR
  • 121 Answers
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
tborn6
  • 700 Answers
SOURCE: the refrigerator icemaker does not make ice.
you have to hold in the ice type and the childlock button for about 6 seconds and that will take the filter light off. To reset the ice maker open the freezer door and then pull out the ice bin. on the bottom of the ice maker theres a button that you have to hold in to reset the ice maker. Good luck and thanks for using FixYa
Posted on Jan 21, 2009
tborn6
  • 700 Answers
SOURCE: Samsung Refrigerator Model RS2533SW - Ice Maker Stuck
did that work?
Posted on Feb 04, 2009
Where is the reset button on my samsung refrigerator ice maker?
There is a test button on them if icemaker is in botton draw freezer section button is located on the bottom front on the icemaker its a small square button. If its the icemaker in frig section button on the right side on icemaker it is rectangular rubber coated hold about 10sec
Feb 14, 2017 | Samsung Refrigerators
Icemaker is not working properly. It will only make ice after the reset button is pushed.
If the ice room is not getting/staying cold enough, the unit will not harvest the ice and proceed through the cycle... First step in troubleshooting is to determine if the compartment the icemaker sits in is cold enough, if it is, then you have to test the ice room temp. sensor to see if it is not sending the correct temp signal to the main board. These icemakers are modular and pretty much have to be replaced completely if the temperatures and sensor check OK. Samsung Refrigerator Temperature Sensor DA32 10104N
Jun 21, 2016 | Samsung RF263BEAESR Stainless Steel 26 cu....
My samsung model RF4289Hars refrig ice machine wil not make ice now i pushed on the button then it said to push reset button where is that Gary
The reset button should be on the icemaker, mine is a clear rubber button, I have my icemaker in the door so you fridge maybe different.
Jun 09, 2015 | Samsung Refrigerators
Ice making not making ice
Cycle the icemaker with the reset button. It is located on the bottom-front of the icemaker. Press and hold for 8 seconds to complete a cycle. You should hear an audible reset tone from the refer when complete. If it still doesn't work later in the day, it may need replaced. These units are well known for deplorable ice making capabilities. Samsung considers 60-72 cubes per day to be acceptable. I consider it an insult. For the icemaker reasons alone, I am looking into another (domestic) brand.
May 30, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung RF263 icemaker not filling with water
the fridge has an electric solenoid valve to let water in (just like your clothes washer) it is located where the water line goes into your fridge at the bottom in the back find,check, clean or, replace it.
Dec 03, 2013 | Samsung Refrigerators
Replaced Icemaker motor on Samsung SxS fridge...is there a reset button? or just wait?
After the ice maker sensor registers that the temperature is below 10 degrees it will start automatically
Jun 04, 2012 | Samsung Refrigerators
My gss25lswass don't make ice, some people tell my about the reset button, where are this button?
Greetings.,
I do not know of any reset button but check to see if there is any ice frozen in the fill tube that brings water into the icemaker..if its froze up this will prevent i/m from working..you can melt ice with hairdryer for temp service..now, if its not froze up..see if there is ice in the mold of icemaker and if it is..the i/m did not come on for some reason...if the mold is empty then it could be a bad water valve...
Jan 21, 2011 | GE GSL25JFPBS Side by Side Refrigerator
My samsung model #RS2578BB AUTOMATIC ICE MAKER IS NOT MAKING ICE PLS ADVISE
TOOLS NEEDED:
Eyes (fair to good shape)
#2 phillips screw driver
Flashlight
Lets assume it was working at one time right? And the FREEZER temp is BELOW 20degs
REMOVE storage bin to see icemaker.
LOCATE test button on underside or rightside of clear motor asembly.
(should be black)
Press until icemaker starts, then release button. Watch the tray twist and return to upright the should fill with water.
If icemaker worked: ICE SENSOR MAYBE BAD> ORDER NEW ICEMAKER IF THE ICE DOES NOT EJECT AFTER 4
If icemaker did not Start by pressing the test button.: UNPLUG the frig or go the Main Service Panel to the house (BREAKER BOX) and shut off the power and verify NO LIGHTS INSIDE THE FRIG>
Remove the concealed screws holding the icemaker to the ceiling.
PULL the icemaker forward to release icemaker. Using the Flashlight
LOCATE the wiring harness on the ceiling. Look for the RELEASE and Squeeze and pull down. Inspect the electrical pins to make sure all pins are equal and secured. If all is well there?
THE PROBLEM COULD BE either: ICEMAKER or Main PC Board
I would order a Icemaker assembly first since it is the least expensive.
1-800-Samsung
Good Luck and Cheers!
Seen It B4
Your Welcome
Jan 02, 2010 | Samsung RS2578BB Side by Side Refrigerator
Ice maker motherboard
call the manufacture, sounds like an issue with the circuit board
Feb 19, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice Maker
Most of the samsung's have a reset button on the bottom front of the ice maker that just pushes in and it should start the cycle.
Oct 22, 2007 | Samsung RM255LASH Side by Side...
Samsung RF220NCTAWW Whtie 21.6 Cu Ft French-Door Refrigerator Bottom Freezer, Energy Star Logo
59 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
