Question about Small Engine Carb Repair Tool: Mini-bike Go Kart Scooter Moped Racing
I have a 1985 honda elite 80 and it has no power on takeoff but once it gets up to speed it seems allright
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Get a compression tester and turn it over 5 times. See if you reading is above 90-150. Anything lower it is the cylinder wear. Check for bright blue spark and maybe dirty carb too. you tube videos can help you fix either possibly.
Posted on May 14, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Turn signals blink once, then stop. I suspect the relay switch but can't find it...1985 Honda Elite 80
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
Jul 10, 2016 | Honda Cars & Trucks
I have a 1986 honda prelude2,0si pgm-fi programed fuel injection 12valve.my car in allgears starts bogging out,towards the end of gears.
1985 Vf750F - Bogs Down On Throttle - Maintenance Questions - VFR ...
www.vfrdiscussion.com > ... > Maintenance Questions
Jan 22, 2014 - 10 posts - ‎4 authors
Page 1 of 2 - 1985 Vf750F - Bogs Down On Throttle - posted in Maintenance Questions: Greetings VF braintrust! I have a 1985 VF750F which I ...
Honda Spree and Elite 50 Forums • View topic - 1986 honda spree ...
www.hondaspree.net/phpBB3/viewtopic.php?f=3&t=18521
Apr 9, 2011 - 12 posts - ‎4 authors
Hi all I am new to thie forum. I recently bought a used rebuild Honda Spree. The guy I bought it from ran super unleaded in it and mixes klotz ...
250 bogging down under full throttle. - Honda Rebel Forum
Dec 02, 2015 | Power Flow 1986 - 2001 Honda Prelude Mud...
2004 Honda Elite 80 Base will not start
Hi, Mskittleboy9 and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
new to the honda elite 80 starting problems
Scooter Troubleshooting Scooter won start All about Scooters http://www.motorscooterguide.net/Manuals/Honda_CH80_Service_Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Apr 14, 2013 | 2004 Honda Elite 80 Base
2006 Honda Elite 80 wiring diagram@
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Honda Elite 80 wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda CH80 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://www.jacksscootershop.com/maintenance/Honda_CH80.html http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Aug 26, 2012 | 2006 Honda Elite 80
2004 Honda Elite 80 cam timing
Hi, David for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
2004 Honda Elite 80 cam timing Google Search
How To Set Cam Timing
http://mybikemanuals.com/honda
Aug 05, 2012 | 2004 Honda Elite 80 Base
I have an 1985 mercedes benz 300D. In the winter, the car runs about 80 degrees C. Once in a while, the heat quits and I have to slow way down and then speed up to cruising speed and the heat returns. ...
check for any coolant leaks, running low will cause an air pocket, you did not specify mileage on vehicle, but if any chance your thermostat, upper and lower radiator hoses may also be colapsing. good luck.
Jul 05, 2011 | 1985 Mercedes-Benz 300
I have a350 chev motor 700r4 trans 10bolt 8.5 rear what ratio to run in rear end it has 273's
273 will work for gas milage and speed. if you want some fast takeoffs, lower top speed, and bad gas mileage then go to around 3.50 maybee even 4.11
i would shoot for around 3.50
Apr 25, 2010 | 1985 Chevrolet S-10
Sputtering at low speeds and takeoff
your low speed jets are stopped up ,the carbs need cleaning, go to walmart a buy some SEAFOAM, poor it in your gas tank ,start it up on choke, and when it start ot clear up take it off of choke, or ride it until it clears up. after it starts running good get it synchronized
Mar 27, 2009 | 1986 Honda GL 1200 Interstate Gold Wing
Small Engine Carb Repair Tool: Mini-bike Go Kart Scooter Moped Racing Logo
83 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
