Question about Dehumidifiers
Ford galaxy 1.9tdi keeps cutting out then starts no problem must be something turning pump off lots of people have same proplem but not telling what fixs it
  • 96 Answers
Crankshaft sensor can cause this kind of behaviour does it have the tandem pump on it as these are the best ones to have been put on these engines failing the crank sensor there is a relay under the dash in the fuse box somewhere that also causes this behaviour although I'm not actually sure this happens on the diesel pd engine best to check on the ford forums
Posted on May 07, 2014
Car keeps cutting out
I assume you are talking about the AC compressor. Low gas or low evaporator temperature will cause it to cut out, If it is blowing relative warm air it is low on gas.
Apr 19, 2014 | Dehumidifiers
I have an whirlpool gold ad50gpusb from canadian tire. The pump will no longer pump via the clear rubber hose and instead the water accumulates in the bucket. Do you know if there is a simple fix to...
For the others who follow
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
Sep 24, 2013 | Dehumidifiers
Can I continuous drain this unit with a hose into a house drain longer then 6 feet from unit with a good pitch.or do I need a ejector pump.
Unfortunately, Russell the length of the hose can not exceed 5 feet. If you're using it in a basement application, you may can stretch it to 6 feet to the floor drain, if you get the unit up off the floor by about 6", onto something sturdy, that can handle the weight of the unit & the vibration. I don't think an ejector pump is the answer. As it would require a sump for the water to drain into and the pump would have to be located in it. Just a lot of extra expense, that really isn't worth it.
I hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby DDR5009EE Dehumidifier
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
White westinghouse dehumidifier freezing up
hopefully its not the coolant pump seizing. the only simple thing that goes wrong with those is the water full switch, which turns off every thing. try playing with the float thing in the tank, you shoud here clicking of the switch on and off
Jun 15, 2009 | Whirlpool AD70USS Dehumidifier
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
Dehumidifier
As for the drain most have a plastic pan and this is sometimes the type that has to be removed and dumped or a hose has to be attached and the hole it attaches to has to be cut out for self draining.
If the threads are fouled up all I can suggest is a lot of Teflon tape or pipe dope or cut out and replace the fitting with something that will correct the problem.
If this helps please rate me as high as you can and thank ytouu for using fixya.
Aug 26, 2008 | LG LHD65EBL Dehumidifier
Dehumidifer seems to run constantly
With that low of a setting it will most likely be kicking in alot more often. Most people run their dehumidifiers between 60-65%. It is a matter of preference. Also some basements hold out moisture more than others. There could be alot of variables affecting this. One thing you need to make sure is that you have the correct placement. Make sure you dont keep it near the sump pump or any other standing water because those areas have more humidity due to the water being there. Also make sure it is not in an area like a laundry room because when your washing machine despenses water it is despensing moisture into the air. I try to keep it at a central location if at all possible and away from areas that have water. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Sep 06, 2006 | LG Goldstar LD65EL Dehumidifier
Dehumidifiers Logo
80 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
