Question about Durabrand HT-3915 System
My remote is broken how I get a new
Not working I changed the battery not working . Need a new 1
Why is my remote not working?
If new batteries installed correctly do not get it working again, it probably has failed. Before giving up, check for damaged, corroded battery contacts.
Jan 04, 2018 | Apple MC377Z/A Device Remote Control - For...
Clicker garage door opener
I don't believe that you need to configure it.
It should be preconfigure to work.
What i think after revising the manual and from past experience with car remotes, the type of socket used for the battery inside the remote itself is often missing or broken solder. To make this more clear, the battery socket might need to be resolder on the small circuit board inside your remote.
good luck
Nov 29, 2013 | Viper Televison & Video
Trouble shoot Security system 1998 Range Rover
Sounds like the contact in the key remote has been shorted or broken. It has happened to many of my remotes. If you shake it does it sound like something is rattling around inside? If so, its unfortunately broken and you need a new one.
Nov 20, 2012 | 1998 Land Rover Discovery
Logitech harmony remote 890 battery and new battery door the clip
If you live in the US, you can call the Logitech Sales Line at 1-800-231-7717 to buy a new battery cover and battery.
If you're from somewhere else let me know and I will tell you how to get replacement parts.
Feb 08, 2010 | Logitech Harmony 890 LCD Remote Control
Sensor for remote is not working on the tv
Tries a little Alcahol with a Q tip clean the tv IR sensor,do the same to the remote and change batteries,tv sensor saldom broken,only remote all the time.Tries this Website 1-800-Remotes Factory Original for new remote get the exact or very close to the original.
Sep 30, 2009 | Televison & Video
REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
May 27, 2009 | JVC LT-26X575 26 in. LCD HDTV
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Bush 15" conmbo DVD TV
1) change the batteries
2) make sure nothing is between remote and TV
or
3) you may need to buy a replacement all for one type remote because this one is broken.
Jul 27, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Durabrand HT-3915 System Logo
37 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
