Question about GE JVM1790WKWW White Profile 1.7 cu. ft. Capacity Convection Over the
Why does the microwave have no power? - GE JVM1790WKWW White Profile 1.7 cu. ft. Capacity Convection Over the
    Problem Solver:
  • 13 Answers
Check if it is pluged in
Posted on May 07, 2014
My microwave keeps running
Thank you for your post, Lou!
From my understanding your Frigidaire microwave continues to run and when you press the second key your turntable will turn. This sounds like a potential issue with your keypad or control panel. I would recommend performing a reset on your microwave and you can do that by disconnecting power from it for at least ten minutes. This will help clear out any miscommunications within your microwave. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Jun 05, 2015 | Frigidaire Gallery FGMV154CLF 1.5 cu. ft....
Why is there no power in microwave?
sounds like a blown fuse but water takes 20 minutes you must have had 10 gallon in it .
Feb 20, 2015 | GE 30" 2.0 cu. ft. Sensor Microwave Oven
I have tripped the cam plates that hold the door closed on my Maytag MMV5208WW1 microwave. So now the door won't close and the microwave won't start. How do I reset the cams?
up plug the Microwave from the power take the cover off and you will see the cam plates make sure thy lock replace cove and then do a test do not turn on when the cover is off or pluget in.
Jan 08, 2015 | Maytag MMV5208WW - 2.0 Cu. Ft....
Model fpbm189kf turns on no heat. loud noise when first on then regular sound. relay ? lamp?
Thank you for your post, friend!
I understand that your Frigidaire microwave, FPBM189KF, is not heating. It could be a possible issue with your control panel or magnetron. I would recommend performing a reset on your microwave and you can do that by unplugging your power cord or flipping the household circuit breaker. If that does not help solve your issue I would consult a professional for proper diagnosis and repair. Hopefully this is helpful. -Matt
Oct 11, 2014 | Frigidaire Fpbm189kf Microwave
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Replacing light bulb
make sure the power is off and unscrew it with long nose pliers
Sep 10, 2013 | Maytag MMV5208WB - 2.0 Cu. Ft....
My Siemens countertop stove says 'locked' and I don't know how to unlock it.
You can also try the below procedure in addition to the one i provided during our chating period. it may also be helpful to you.
Make sure your GE microwave is plugged in.
Press and hold the "Clear/Off" button on your microwave's keypad for around three seconds.
Wait for the "L," which indicates the microwave is locked, to disappear from the display.
Open the microwave using the open latch button.
Take care.
May 23, 2010 | Cooktops
Ultrex microwave won't start
hi gud day.did u have a manual to check before to try to operate, or u think the item is ok to use in ur country coz some model & brand have a diff in tecnical power,what HSN or ur unit is stock for how many years?sometimes this the coz of the problem.tnx
Feb 02, 2009 | Cooktops
GE JVM1790WKWW White Profile 1.7 cu. ft. Capacity Convection Over the Logo
69 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
