Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Do i need a convertor box for my 51" hitachi tv ?
Plus how can i switch my tv from analog to digital
ladywinn
  • 5138 Answers
SOURCE: Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Posted on Dec 27, 2008
AZSkiBum
Your Hitachi 43FDX01B is HD-Ready, which means it has high definition capability, but it needs an HDTV Tuner added to it. DTV converters can only give you Standard Definition resolution. You can browse HDTV Tuners Now for the different types of HDTV Tuner that are available.
Posted on Jan 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: is my Hitachi 61uwx10b ultravision hd ready
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Posted on Jun 06, 2009
SOURCE: is my hitachi 46f500 projection tv ready for switch to digital
http://www.shopping.com/xPF-Hitachi-46F500
HDTV-Ready - Requires separate receiver to view HDTV signals.
Posted on Jul 10, 2009
  • 1779 Answers
SOURCE: Is my Hitachi 60V500A tv digital ready for local
You'll probably get 480p if you use a cable box using the RGB outputs from that and plugging them into your RGB component input on the jack panel . You won't get 720p on that set, but you'll wind up with a clearer picture than regular RF. So, your answer is no, you won't won't get it without a box if your using an air signal.
Posted on Oct 28, 2009
Does this TV have ATSC digital capability or will I need a digital tuner to use a digital antenna?
If the TV is an analog only you will need to get a digital converter box to be able to use a digital antenna. You can find this online by doing a Google search or you can try Ebay they have a bunch of them 662results for tv digital converter box
May 05, 2015 | Hitachi 51F510 51" Rear Projection...
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Sound went out, all I get is white noise that you cannot mute. Happened when I changed from high def to regular channel. Even with everything unhooked still just white noise.
Analog regular channel TV was turned off mid 2009. You need a digital channel convertor box to receive the new digital channels... The analog ones went bye, bye in the USA. Without the box you will just get noise.
Jan 02, 2010 | Hitachi 50V720 Television
Digital receiver
no it dosent
if your yousing a an antena you need a box
Jan 13, 2009 | Zenith H25F36DT 25" TV
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Do I have an analog or digital TV ?
You have an ANALOG set. After 2/17/09, you will need to be connected to cable, satellite or get a convertor box to watch this set.
Mar 24, 2008 | Televison & Video
HITACHI ULTRASCAN 53FDX01B TV- do I need analog to digital conversion box ?
you do not have a digital tuner if that is what you mean. if you have a cable box you do not need to worry about this stuff but if you want to pick up over the air signals sometime next year you will need some type of hd to sd converter
Mar 19, 2008 | Televison & Video
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
