Question about Zodiac Jandy AquaPure Ei up to 35k 120/240v Hard-wired
System will not start up after a winter's rest!
We have a Jandy AquaPure35 (in-ground pool) that we are trying to turn back on after its winter rest. It is direct wired (240v) to our pump and during the winter the circulation light would always shine when the pump was running. Now when we connect the wiring to the electrode the light goes out and nothing is indicated on the readout. The water temperature is 74 degrees and there is ample salt content in the pool. Last year we had to replace the power supply and wonder if this is the problem again or could the electrode cell be bad ? Both fuses on the power supply are good and the flow light goes out only when you make the last connection -- no matter what order you connect the wires.
    Scholar:
  • 126 Answers
On page 41 of the manual, a no-display indication can be related to a loose ribbon cable (check the cable is fully inserted into the connector), or a loose or bad connection at the white connector between the transformer and the PC board ("Check connector at white plug to insure proper connection. If burnt connector contact authorized service representative.")
As you operated the pool during the winter, did you remove the sensor and replace it with an optional spool piece, or did you leave the sensor in operation and perhaps subject it to freezing? The sensor can be permanently damaged if it was subjected to freezing.
Try removing the cell and cleaning it.
First I would go through and check all of the connections. If they are OK, and as this occurs after you make the connection to the electrode, I can't help to wonder if the electrode is clogged or damaged beyond repair.
The correct method for winterizing is section 6.5, on page 40, of your manual.
Posted on May 07, 2014
Testimonial: "Dennis: We removed and cleaned the electrode for winter storage; all connections are good. Yet no reading of any kind is shown when powered up. Also, cleaned all electrode connections! I think that I may have a bad TS Control PCB assembly, or the Power Supply is out. Don't know how to determine which?"
  • Dennis
    Dennis May 09, 2014
    It's hard to say, could be those two, or the wiring gone bad, or the electrode. At this point I think you will have to call your dealer and see what they say. (If you have no dealer, you can call Jandy tec services at (707) 776-8200 extension 260, and see what they say.
Jandy pda stuck on waiting mode
try changing batteries then shut system off turn back on then turn on PDA if still the same take off front top cover of aqualink make sure 4 pin red plug is connected and tight
Aug 19, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
So we have the jandy laars lx.... we have had it for 3 years no problems we use it with pool and spa and its gas........ the buttons work you can choose pool or spa just fine but when you choose one... the...
This heater wont start if the pressure switch is bad or clogged. Remove the pressure switch and clean it out really well, or just purchase a new one. It should only be $30-$50 depending on where you go to get it
May 03, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How to winterize ? i have the jandy lrz model 125000 natural gas and what to know how to close down and winterize
turn off gas valve and blow water out with air then with RV antifreeze when you see antifreeze coming out its good see you tube video on pool closing
Oct 27, 2010 | Jandy Legacy LRZ 125000 BTU Millivolt...
Jandy aqualink rs4: pool has been winterized with the spa left on. when switched from service mode into auto mode system switches back from spa into pool mode (motorized valve switches back to pool mode)....
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Nov 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
Nov 22, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Zodiac Jandy AquaPure Ei up to 35k 120/240v Hard-wired Logo
70 people viewed this question
Top Zodiac Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Zodiac Electrical Supply Expert? Answer questions, earn points and help others
