Question about Whirlpool Gold 30" 2.0 cu. ft. Microhood Combination Microwave Oven
When magnetron shorts out is thermostat attached to magnetron housing automatically shot? along with magnetron?
I can't say. It was expensive to replace the magnetron that we decided to get a new one. It was maddening that it lasted only 4 years
Posted on May 07, 2014
Where is the thermostat housing on a2002Mazda tribute
Hi Ashley, The link below is a short youtube video of how to find and replace your thermostat, This isn't a mazda but it shows (All Cars) the hose attached to the top of the radiator is attached to the thermostat housing at the other end... Meaning radiator and thermostat housing are attached by a black hose, Please watch the video...CHEERS..
https://www.youtube.com/watch?v=RIC6Z4D6Q3E
Apr 01, 2016 | Cars & Trucks
The Microwave shut off after a few seconds. I removed it from the wall and took the cover off. I fired it up and initially it behaved the same. I checked wire connectors that were readily available. Did...
It will get hot in a very short period of time. Could you have set the time for a few seconds instead of a few minutes? Thermal issues normally take the unit out until replaced. They are one shot thermal protect devices.
Sep 06, 2013 | GE SpaceMaker Microwave Ovens
How do I replace the thermostat on my granddaughter's 1995 Lincoln Continental?
ATTENTION!!! READ ALL OF POST BEFORE CONTINUING!!!
First you need to find the thermostat housing either located on the Block or the radiator... then you need to go to a car parts store tell them the year of the car and get the Gasket and the thermostat along with the gasket glue. remove the 3 to 4 blots from the housing and remove the old thermostat place the glue on the side of the gasket the instructions indicate. attach the gasket as indicated and then put in the new thermostat. all components with glue or pieces of the old gasket must be shaved off with a razor or a knife very carefully. any scratches will ruin the housing. also try not to apply to much torque to the bolts when taking them off or putting them back on you will crack the housing and possibly the block.
Nov 21, 2010 | 1995 Lincoln Continental
Where to locate the thermostat on an 03 pontiac grand am?
Not sure which engine you have so please pick the appropriate engine:
2.2L Engine
  1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
  2. Drain the cooling system.
  3. Remove the thermostat housing to water pump feed pipe bolts.
  4. Remove the thermostat housing to water pump feed pipe.
Thermostat mounting-2.2L engine
3.1L Engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system to a level below the thermostat housing.
  3. Remove the air cleaner assembly.
  4. Disconnect the surge tank line from the thermostat housing.
  5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
  6. Remove the thermostat.
3.4L Engine
  1. Drain the cooling system.
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat
  7. Clean the mating surfaces.
Nov 01, 2010 | 2003 Pontiac Grand Am
How to install thermostat
from autozone.com
2.2L Engine
  1. Fig. Thermostat mounting-2.2L engine
  2. Remove the thermostat.
To install:
  1. Install the thermostat.
  2. Install the thermostat housing to water pump feed pipe.
  3. Install the thermostat housing to water pump feed pipe bolt. Tighten the thermostat housing to water pump feed pipe bolt to 89 inch lbs. (10 Nm).
  4. If equipped with an automatic transaxle, install the exhaust manifold, as outlined in this section.
  5. Fill the cooling system.
3.1L Engines
To install:
  1. Clean all gasket surfaces completely.
  2. Insert the thermostat in the intake manifold.
  3. Attach the thermostat housing to the intake manifold.
  4. Install the mounting bolt and nut. Tighten to 18 ft. lbs. (25 Nm).
  5. Install the air cleaner assembly.
  6. Connect the surge tank line to thermostat housing.
  7. Refill the cooling system.
  8. Connect the negative battery cable, remove the radiator cap, then start the engine. Allow the engine to run with radiator cap removed, until the upper radiator hose becomes hot (thermostat open). With the engine idling, add coolant to the radiator until the level is up to the bottom of the filler neck.
  9. Install the radiator cap, making sure the arrows line up with the overflow tube.
Sep 25, 2010 | 2003 Pontiac Grand Am
How to change the thermostat
Alero, Grand Am 1999-2005 Thermostat - Removal & Installation 2.2L Engine
  5. Remove the thermostat.
To install:
3.1L Engines
To install:
3.4L Engine
To install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  5. Install the air cleaner.
  6. Fill the cooling system.
  7. Inspect the system for leaks.
Hope this help (remember comment and rated this).
Apr 04, 2010 | 1999 Oldsmobile Alero
Evry thing works except the food is not heated. It makes the noise, timer counts down..
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side of the blower housing, or magnetron tube assembly)))
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My ge microwave spacemaker 1800 won't heat my food pls help
(((The fuse is located inside the unit along side the magnetron, near the blower housing.)))
Nov 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the thermostat at on a 1999 Concorde
On the 2.7L engine, follow the lower radiator hose to the engine. Where that rubber hose stops and it attached to, that is the thermostat housing. Remove that housing and the thermostat is sitting there.
On the 3.2L and 3.5L motor, follow the heater hoses to the engine along with the radiator hose and that is the thermostat housing. Remove the housing and there is the thermostat.
Oct 25, 2009 | 1999 Chrysler Concorde
How do i replace the thermostat in a 2001 pontiac montana?
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  6. Remove the thermostat housing and gasket.
  7. Remove the thermostat.
  8. Install the thermostat.
  9. Install the thermostat housing bolts and tighten them to 18 ft. lbs. (25 Nm).
  10. Install the radiator hose to the thermostat housing.
  11. Install the crossover exhaust pipe.
  12. Install the air cleaner and duct assembly.
  13. Good luck...
  14. Fill the cooling system.
  15. Install the thermostat housing and gasket.
  16. Clean the mating surfaces.
Jan 15, 2009 | 2001 Pontiac Montana
Whirlpool Gold 30" 2.0 cu. ft. Microhood Combination Microwave Oven Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
