Question about Zodiac Jandy AquaPure Ei up to 35k 120/240v Hard-wired
We have a Jandy AquaPure35 (in-ground pool) that we are trying to turn back on after its winter rest. It is direct wired (240v) to our pump and during the winter the circulation light would always
See comments above!
  • 957 Answers
What is your question about the pool pump.
Posted on May 08, 2014
Pool pump will not turn on
check voltage to pump switch if voltage turn off breaker remove back of motor where wires go in make sure wires are tight if tight try to turn motor shaft by hand then try again if doesnt work need new motor or pump
Aug 24, 2014 | Jandy Pool & Spa
System will not start up after a winter's rest!
On page 41 of the manual, a no-display indication can be related to a loose ribbon cable (check the cable is fully inserted into the connector), or a loose or bad connection at the white connector between the transformer and the PC board ("Check connector at white plug to insure proper connection. If burnt connector contact authorized service representative.")
As you operated the pool during the winter, did you remove the sensor and replace it with an optional spool piece, or did you leave the sensor in operation and perhaps subject it to freezing? The sensor can be permanently damaged if it was subjected to freezing.
Try removing the cell and cleaning it.
First I would go through and check all of the connections. If they are OK, and as this occurs after you make the connection to the electrode, I can't help to wonder if the electrode is clogged or damaged beyond repair.
The correct method for winterizing is section 6.5, on page 40, of your manual.
May 07, 2014 | Zodiac Jandy AquaPure Ei up to 35k...
Jandy Zodiac FloPro 2HP connecting Red Wire to which screw L1 or L2?
follow the owners manual.
if you are hooking this pump up as 220v, you will have two hot wires. one goes to L1 and the other to L2. it matters not which is where as they are both supplying power. be sure to connect the internal ground wire AS WELL as the bonding wire to the outside lug
Apr 28, 2014 | Zodiac Jandy 2Hp Flopro Pool Pump For...
240v circuit to 120v pool pump
Listen - you had three wires feeding your old 240 volt pump. Two were hot and one was a ground. To run your new 120 volt motor just connect one of the two hots to the motor along with the ground. Cap off the remaining hot wire so nada bad happens and you are good to go.
Apr 08, 2017 | Pool & Spa
Replaced old Sta-Rite pool motor with new 1.5 hp Emerson 1081 pool motor. Used exiting 240V wiring. Wired L1 to 120V (black wire), L2 to 120V (red wire), Ground to green ground Screw (green wire). Turned...
Get qualified electricrian to help. I've had the same problems with my pool pump. If you make one little mistake, it could be your last.
Oct 05, 2011 | Pool & Spa
Jandy Stealth wired internally for 220V. There are three available terminals, the "A", the "B" or the L1 but I only have two red wires. Where do they go?
look at the schematic on the side of the motor it will tell you where the two red wires go probably on L1 and L2 green to ground the case
Feb 27, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
I need a wiring diagram for hayward pool filter model K48m2n11b3
Are you trying to wire a pool pump?
I found manuals at the Haywood site > I saw nothing for K48m2n11b or anything close to that number
http://www.haywardnet.com/inground/products/manuals.cfm
But lets work on the problem and see if I can give you some help:
After opening a few manual and searching for the word 'volt' and 'pump' ... each manual talks about 'pumps' generically, as if the pump is a separate purchase item.
Lower down on the manual page they have a list of pool pumps. A search for the word 'volt' inside the pump manuals says 'match supply voltage to motor nameplate voltage.'
As you know, each electric device has a label showing voltage, wattage, etc. Your pump should show 120Volts or 240V. I didn't see any mention of 3 phase wiring, so I assume your Haywood pump runs on typical residential wiring? And that you are not using 440Volt or 3 phase.
The 120Volt pump will have a black, white and bare ground.
The 240Volt pump will probably have a black, white, red and bare ground
The 240Volt pump could have a black white and bare ground
First the 120V pump:
The 120Volt line from your breaker box will have a black Hot wire, white Neutral wire and bare ground >>> this wire connects color-to-color with pool pump
Next the 240V pump with black, white, red and bare ground
a) The 240Volt line from your breaker box can have the same 4 wires, in which case they connect color-to-color
b) The 240Volt line from your breaker box could have a black white and bare ground, in which case the black goes to black, the white goes to red, the bare coppers are connected, the white pump wire is capped off and not used. If pump does not operate with this wiring, another line from the breaker with wires that match pump might be necessary.
The 240V pump with black white and bare ground
a) The 240Volt line from breaker can have black, white, red and bare ground, in which case the black goes to black, the red goes to white, bare grounds are connected, the white wire is capped off
b) The 240Volt line from from breaker can have black white and bare ground, and this connects color-to-color to the pump
HOW do you know if line from breaker is 120V or 240V?
If you know which breaker wire is connected to, then it's easy
If you do not know which breaker
-turn off power
-separate wires so they can be tested
-use ordinary tester
-stand on dry boards
-tape tester leads to sticks so hands are away from power
-turn on power
-test each wire to bare copper
-tester lights up on Hot wire
-120V line will have 1 Hot wire
-240V line will have 2 Hot wires
Oct 18, 2010 | Garden
Jandy aqualink rs4: pool has been winterized with the spa left on. when switched from service mode into auto mode system switches back from spa into pool mode (motorized valve switches back to pool mode)....
the only thing you can do since the jandy does not have a "winter" mode is switch the valves off. Once you have the valves in spa mode, there should be a toggle switch on the valve actuators. You can set the switches to the middle position and that will lock them in that position. You will probably have to re-winterize the pool lines.
Nov 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I am trying to connect my new pool motor. I have 3 wires coming out of the box. a black one 120v a white one 120v and a copper (ground). How do I test if it has 240v? How can I connect the motor so works....
Most probable cause is that you have the black and white on the same phase, and that's why you have 120 volts from black to ground and from white to ground, but 0 across black and white. If the motor ran on 120 volts, why are you connecting it to 240?
In any event, in order to get 240 volts, move the white to a circuit breaker that is directly above or below the breaker that feed the black wire. You are supposed to use a 2 pole breaker for 240 volts anyway
Jul 23, 2009 | Pool & Spa
Zodiac Jandy AquaPure Ei up to 35k 120/240v Hard-wired Logo
54 people viewed this question
Top Zodiac Electrical Supplies Experts
Steve
Gene Haynes
Are you a Zodiac Electrical Supply Expert? Answer questions, earn points and help others
