Question about Ingersoll Rand Rotary Screw Air Compressor - 15HP/125PSI IR-UP6-15C-125
How do I reset the Service Light on Ingersoll rand UP6-15C Air Compressor?
  • 54 Answers
SOURCE: I have a Ingersoll Rand P185 WJD air compressor
Do not use 30 wt oil. It will wreak the oil/air seperator filter. Use Ingersoll Rand Pro-Tec fluid. It will hold approx 3 gallons.
Posted on Nov 19, 2009
compman66
  • 169 Answers
SOURCE: ingrsoll rand air compressor repair manual
Most manuals are available from Ingersoll-Rand, I am not sure they sell a repair manual. however they do have owner and parts manual for the pumps that show breakdown of the pump and can be very handy for reference when working on one. Contact your nearest IR air center and ask for a copy of the manual, and most times they can provide you a copy for little or no cost.
Posted on Jan 15, 2010
  • 243 Answers
SOURCE: my tow behind air compressor ingersoll rand 185
press load button or toggle switch
Posted on Feb 08, 2010
compman66
  • 169 Answers
SOURCE: The compressor starts and stops after a short
More than likely it is a problem with the inlet control, commonly I have found wear in the throttle linkage can cause this or a faulty sump pressure sensor that is out of calibration.
Posted on Mar 07, 2010
compman66
  • 169 Answers
SOURCE: Ingersoll Rand Air compressor loosing pressure
sounds like you have a problem with the discharge valve on the secondary cylinder, some I.R. pumps rely on the cylinder head valves to hold back tank pressure when the pump comes to a stop. the line down to the crankcase in front of the crank is a unloader valve that dumps the air pressure inside the pump to allow the next restart. I think that once you drain the tank and remove that cylinder head you will find a defective valve in the head.
Posted on Mar 26, 2010
My ingersoll rand compressor is always showing service is due yet its not always the case what can be the problem
Need to reset the service alarms after doing the service. The controller has hour counters for air filter oil filter oil change and separator. All the controller knows is the the hours have counted down setting of service due message.
May 10, 2016 | Ingersoll Rand Air Tools & Compressors
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
May 07, 2012 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
Manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Jan 09, 2009 | Ingersoll Air Tools & Compressors
Ingersoll Rand Rotary Screw Air Compressor - 15HP/125PSI IR-UP6-15C-125 Logo
101 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
