BACHLT@AOL.COM MY NETFLIX SCREEN IS STUCK ON MY TV AND I CAN'T HIGHLIGHT OR MOVE ANYTHING
  • Bent A Christensen
    Bent A Christensen May 09, 2014
    I solved yje problem by changing the batteries in my remote
When I click to open Netflix from Roku, there is no title pictures showing in the little boxes. There are only little pictures of a TV. What happened
Roku
  1. Press the Home button to navigate to the Roku home screen.
  2. Select Settings.
  3. Select Netflix Settings.
  4. Select Deactivate this player from my Netflix account.
  5. Select Yes. The device is now deactivated.
  6. Select Netflix from the home screen and follow the prompts to reactivate the app.
  7. Sign in to your account and try Netflix again.
All other Roku models
  2. Highlight the Netflix app and press the star key on the remote.
  3. Select Remove channel.
  4. Select Remove channel again to confirm.
  5. From the home screen, select Streaming Channels.
  6. Select Movies & TV.
  7. Select Netflix.
  8. Select Add Channel.
  9. Select Go to channel.
  10. Sign in to your account and try Netflix again.
Sep 25, 2017 | Televison & Video
I have to have activation code to connect my Roku to netflex
have a read
Using Netflix on your Roku - Netflix Help Center
https://help.netflix.com/en/node/23886
  1. Cached
  2. Similar
Press the Home button to navigate to the Roku Home Menu. Highlight the Netflix app and press the star key on your remote. Select Remove channel. Once you confirm by selecting Remove channel again, the device will be deactivated. Deactivating the Roku 2 in this manner will remove the Netflix channel from the main menu.
How to Setup Netflix on My Roku ' Techwalla.com
https://www.techwalla.com/articles/how-to-setup-netflix-on-my-roku
  1. Cached
Netflix Connection. Select the Netflix icon on your television screen with the Roku remote to start Netflix. Follow the directions on the screen for an activation code that you enter on the Netflix website. Log in to Netflix, go to "Your Account & Help" and scroll down to "Watching Instantly on Your TV or Computer."
Netflix Help - Roku
https://support.roku.com/hc/en-us/articles/208756518-Netflix-Help
  1. Cached
  2. Similar
If a code appears, you may enter the activation code at netflix.com/activate. ... Is there a maximum number of Roku players I can link to my Netflix account?
I am having problems linking my Roku player.
https://support.roku.com/.../208754508-I-am-having-problems-linking-my-Roku-pla...
  1. Cached
  2. Similar
Follow these suggestions if you are having trouble activating/linking your Roku player: I entered the link code on the web page and submitted, but nothing is ...
Roku resetting Netflix activation code - Roku Forums
forums.roku.com > ... > Roku Streaming Player General Discussion
  1. Cached
Feb 10, 2010 - After idle, the netflix channel on roku requests an activation code and thus, ... This happens to my parents player often, but never (so far) to mine. ... "phones home" back to netflix every once in a while and if it doesn't connect a ...
Nov 10, 2016 | Roku Televison & Video
How do I get Netflix to work on a Proscan tv please? Its model no is PLDEDV3292-UK-B
Need help, screen is stuck saying "Please Run Chan ...
community.insigniaproducts.com/.../Televisions/...Please-Run.../44406
Feb 22, 2012 - However, after the initial setup, I have a problem where the TV keeps on saying "Please Run Channel Auto Scan" and I cannot do anything ...
Netflix says "Unable to complete requested action" on my ...
https://help.netflix.com/en/node/10493
NetflixUnable to complete requested action. Your Roku is unable to complete your requested action at this time. Please try again la
Jan 08, 2016 | Proscan Televison & Video
Directions for activating netflix on a samsung 4 4000 led tv
I had the same problem the bottom line is call Netflix and they can walk you through it
Netflix Customer Phone Number Shortest Wait Best Support
888-638-3549
Feb 06, 2015 | Netflix
How do I install netfix on TV
how to guides the bottom line either use a net smart tv or get a media streamer box like ruku and so many more.
Jan 29, 2015 | Netflix
How do I get an activation code to stream Netflix through my TV?
Assuming you already have an active netflix account, start up the Netflix app on whatever device you have connected to your TV or the app within the TV if it is a Smart TV.
Follow the directions on the screen and choose the links for "Already a Member" or "Login". Once you enter your account information you will be givin an activation code on the screen.
At this point, go the <netflix.com/activate> on another device. You will need to log in once more. Then you will see a field asking for the activation code you see on your TV. Enter it and proceed. You will recieve a message telling you Netflix is activating and depending on the device the netflix app may restart or move to the movie selection screen.
Some older devices can be slow when browsing and it does depend greatly on the quality of your internet connection. Be patient when you first start up the app and enjoy your Netflix!
Jul 19, 2014 | Televison & Video
AOL screen in wrong place - too low - cannot read
Use your mouse to move the AOL screen.
Click and hold the screen and move it up.
Jan 30, 2014 | aol.com
Randckurth@aol.com
call netflix direct on a phone and have them sort out the problems
probably will work good after the 1 month free is used up
Apr 22, 2017 | Computers & Internet
The movies want play
  1. Test your Internet Connection
    1. From the PS3 main menu, navigate to Settings.
      • If you're not already at the main menu, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Select Network Settings.
    3. Select Internet Connection, and verify it is set to Enabled. If it's Disabled, make sure to select Enable.
    4. Select Internet Connection Test.
      • If you are able to connect to the Internet, check your date and time settings.
      • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Refresh your Netflix Iogin information
    1. Begin from the PS3 Home Screen.
      • If you're not already at the home screen, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Navigate to the TV/Video Services section and highlight Netflix.
    3. Press X.
    4. Immediately after pressing X, press and hold both Start and Select and continue to hold them down until a message appears asking Do you want to reset your Netflix settings and re-register?
    5. Select Yes.
    6. Enter your Netflix email address and password.
  3. Reinstall the Netflix application
    1. From the PS3 Home Screen, navigate to the TV/Video Services section and highlight Netflix.
    2. Press the Triangle button on the Playstation controller.
    3. Select Delete.
    4. Select Yes.
    5. Download the Netflix application to your PS3.
    6. From the PS3 home screen, navigate to the TV/Video Services section and select the Netflix icon.
    7. Select Yes on the Are you a member of Netflix? screen.
      • You may be prompted to sign in to your PlayStation Network (PSN) account first.
    8. Enter your Netflix email address and password.
  4. Troubleshoot your Internet Connection
Oct 22, 2013 | Netflix
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
