Question about Stoves Ovens
Stoves genus electric built in oven fault
The open door sign is flashing yet it is shut, the oven will not heat up as a result, any idea of how to remedy this please
  • 145 Answers
SOURCE: Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Posted on Apr 18, 2008
SOURCE: Whirlpool self-cleaning electric built in oven
I have the same problem. Who has a solution?
Posted on Aug 24, 2008
  • 311 Answers
SOURCE: No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
protek480
  • 1714 Answers
SOURCE: Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Posted on Sep 17, 2009
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
The bottom oven door does not completely shutThere is a gap from which heat escapes.The door shuts but then drops open a very little way when pressure is relinquished
When the door is open, you will see some small cross head screws near where the hinges go into the door. These should be tight. If they are, then it could be the hinge failing. Try espares for a new set of hinges, but be warned you will have to take the entire oven out of its housing and both side panels off to get the the hinges.
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Stoves 058568000, grill element meggers out OK but no power supply coming through ! Is there a hidden TOC somewhere . I'm a registered electrician but don't want to have to strip the whole casing off this...
Not too sure of the model, but on the 720 the grill will not operate unless the door is down (microswitch control - you can hear it operate when the door is shut/opened) and the overheat device has not operated.(Cooling fan has to be running)
May 02, 2010 | Stoves 720EF Electric Double Oven
Hi I have just got my new Genus m/f oven the multi funcition I am fine with but I find I have no instructions or recipes for the Genus.Can anyone tell me where I can get some. or download some I am in...
As a US consumer, I am not very familiar with Genus ovens, but I think they are manufactured by Glen Dimplex. Their website is www.gdha.com or try their phone at 0871 222 2502. They may be able to supply you with additional info for your oven. Hope this helps.
Apr 19, 2009 | Stoves Ovens
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
Stoves oven genus 900 error codes
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Nov 18, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
52 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
