Question about Packard Bell (030069) Sound Card
After formatting my pc the sound and cd drive have cease to exist and vga too but i know the type of computer i use
No sound
Posted on Jun 22, 2009
How would i go about formatting a computer?
How to Format a Computer
Want to know how to format a computer hard drive?Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
How to Format Computer Quick Links:
How to Format a Computer with Windows XP
How to Format a Computer with Windows 95, 98, & ME
Wipe All Data Before Formatting
Reinstall Windows XP
Reinstall Windows 95, 98, & ME
Create a Startup Disk
The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.
Your computer should automatically boot from the CD to the Windows Setup Main Menu.
At the Welcome to Setup page, press ENTER.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
How to Format a Computer with Windows 95, 98, or ME
To reinstall Windows, you will need a Startup Diskette and a Windows Installation CD.
Download the Startup Diskette Creator
Note: We recommend using the Startup Diskette available on this page. Other Windows Startup Diskettes may not work with the following steps.
Once you have your Startup Diskette, insert it into the floppy drive and restart your computer.
Select option #1 - Start the computer with CD-ROM support.
After a minute or so, you will see "A:>_".
Type "fdisk" and press Enter.
If asked to enable large disk support, select Y for Yes. (Note: Some versions of Windows 95 may not be compatible with large disk support. Select N here if it does not support the FAT32 file system.)
Select Option #1 - Create DOS partition or Logical DOS Drive.
Select Option #1 - Create Primary DOS Partition.
The drive integrity will be verified.
Unless you are planning to make multiple partitions, select Y when asked if you want to use the maximum available size for the partition and to make the partition active.
The drive integrity will be verified again.
When completed press the Esc key to exit fdisk.
Without removing the floppy disk, press the reset button on the computer or press the keys Ctrl then Alt then Delete and release them together. This will restart the computer.
Again, select the option to Start the computer with CD-ROM support.
When you see A:>, directly above it is a message about your CD-ROM drive. It will tell you the letter assigned to your CD-ROM drive, take note of it.
At the A:>, type "format C:" and press Enter.
Press the Y key then the enter key when asked if you want to proceed with the format.
The format will probably take some time, so be patient.
You will be asked to choose a Volume Label, which is a name for your hard drive. It has no effect on the operation of your computer, you may choose any name you like.
How to Reinstall Windows XP
To reinstall Windows XP or 2000, imply insert Windows CD and restart your computer.
If your hard drive has not been formatted, Windows XP will walk you through the formatting process described above
Your computer will automatically boot from the CD and begin the installation process
How to Reinstall Windows 95, 98, or ME
After formatting your hard drive as described above, insert the Startup Diskette into the floppy drive and restart your computer.
Place the Windows Install CD into the CD-ROM drive.
Type "E:" (where E is the letter assigned to the CD-ROM drive) and press the Enter key.
Type "dir" and press Enter. You will see something like the following:
Volume in drive E is 020409_1121
Direct
Dec 15, 2011 | ASUS Computers & Internet
I want to know how to format a computer system
Hello darlington4 ,
You can't format the supporting OS drive ( usally C ) but if your intention is to install a new OS version on your machine , just insert the install disc and follow instructions . The existing O.S. will automaticaly be erased .
Otherwise , you need to extract the drive from tour machine and format it with another healthy computer by connecting it via usb or as secundary .
Best regards ,
fanaudi
Mar 16, 2011 | Microsoft Windows Vista Home Premium...
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
Window cd delete only some file. i want to format hole harddisk.
what it sounds like to me is, you ran the windows cd and installed it over what was already there with out formatting the drive or partition first.
to start with a clean copy, you have to format the drive, but youll have to delete the existing partition 1st...if your not sure how to do that, just post back and let me know what OS your trying to install.
bill
Oct 12, 2010 | Toshiba Portege R100 Tablet PC
Hi i have one virus in my computer and he block my system and now i want to know if i can format my computer from command prompt but i type format c: and the computer tell me something about parttion can...
Why oo you want to format the C drive, you would not be able to do that. Why dont you try installing some antivirus and try to fix the virus.
In case you still want to format the hard drive and in the process remove the OS, you would need a bootable cd / DVD for the OS. You would need to start the process of re-installing the OS
First change the first boot device in the bios DVD, then insert the bootable CD in the CD Drive, restart the computer and follow the screen instructions, you would get an option to select new installation or repair the existing installation. Please select new install.
Then you would get he option to select the partition to install the OS. select the desired partition.
Then you would get the option to format the selected partition. select the disered option.
and follow the screen instruction an complete the installation.
Jun 27, 2010 | Computers & Internet
How can i format my laptop
Step 2
Step 3
Step 4
Step 5
Step 6
May 06, 2010 | Computers & Internet
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
Hi! how do i format my asus laptop to re-install windows xp
How to Format a Hard Drive with Windows XP
  1. To format a hard drive with Windows XP or 2000, insert Windows CD and restart your computer.
  2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.
  3. At the Welcome to Setup page, press ENTER.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
  7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
  8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
  9. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
Please don't forget to rate me..:-) Thank you much..
Nov 11, 2009 | ASUS Eee PC 900 PC Notebook
M1-M-5312-3CQ plz give me sound & vga thank's
You can download all the required drivers for the Computer compatible to the Operating System installed on it from the link given below:
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html#audio
Oct 24, 2009 | Lenovo 3000 Y410 Laptop
Need to format my hard drive
Firstly before you format the hard drive be aware that when you start the format process you will lose any data that is currently on that hard drive so make sure you backup all important files such as word and excel documents , pictures , music etc...
Formatting Primary HDD
1. Insert the Windows installation CD and restart the computer
2. Your computer should boot from the cd , or ask to press any key to boot from cd
3. at the next welcome screen press "enter"
4.Press F8 after reading the licence agreement
5.If an existing installation is detected it asks if you want to repair it , to bypass this and continue with the clean format press "esc"
6.Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition. (if an existing partition exist press "D" then "C" to start from scratch")
7. If your not worried about partitions jsut press enter to create it the maximum size
8.Choose NTFS file system and press enter
9. After the install has completed follow any instructions it gives you.
10. you're all done now you will need to reinstall software , drivers etc...
Apr 02, 2008 | Computers & Internet
Packard Bell (030069) Sound Card Logo
101 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
