Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD860 tripping the electric - Hotpoint Ultima WF860 Front Load Washer
SOURCE: Changing the door gasket on Hotpoint Ultima WD860
Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
Posted on Apr 07, 2008
  • 1294 Answers
SOURCE: keeps going on test cycle
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Posted on Mar 08, 2009
  • 44 Answers
SOURCE: my hotpoint ultima keeps triping the trip switch.
Hi
f08 means heater relay cannot be actived so try unplugging heater element and see if it stops tripping the electrics.
regards
Posted on Mar 21, 2009
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
apart4u
  • 213 Answers
SOURCE: Hotpoint WD860
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
Posted on May 06, 2010
Hotpoint Ultima WD860 Washer Dryer not rinsing properly. Leaves white residue on dark clothes.
quit using powered detergent .we quit many years ago as it does not dissolve properly in our hard water .no problems with liquid .
Oct 16, 2015 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 Ultima super silent led screen stopped displaying information
My hope is that it is still under warranty. But I assume it is not. I get a lot of parts and diagrams, as well as trouble shooting help from an excellent web source at www.repairclinic.com. Enter your model number and it will give suggestions to check for, as well as order your part. Used it many times.
Apr 04, 2014 | Hotpoint Ultima WF840 Front Load Washer /...
Ultima WD860 - dryer has been stuck with 1 minute left for about half an hour. Have turned it off but obviously my stuf is stuck inside.
Hi!
Please disconnect your WD860 from the power supply. The door lock uses electrical power to stay closed. After you unplug the machine from electrical power, just wait a couple of minutes and the door lock will be released.
Regards,
Bogdan
Aug 26, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
I have hotpoint WD860 and fault F - 02 motor jammed tacho detached.What happened?
likely a piece of the rotor itself is locged inside. Disassembly is required to see for sure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wd860 trips rcd when spinning
fault with motor you will need to replace
Jun 06, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My hotpoint ultima keeps triping the trip switch. it had f08 on the screen but now that has gone, but still trips electrics every time i press start.
Hi
regards
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Keeps going on test cycle
Mar 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
