Question about Zebra P120i Plastic ID Card Printer - P/N P120I-0000A-IDB Start Up Kit
Why is my zebra printer only printing color on one side?
jc2it
  • 58 Answers
SOURCE: zebra 105se printer is printing out of the label on the wright side
It would be best if we had more information, or a picture.
For instance if you told me as the label is printing it does not print on the label, and it appears shifted to the right or front, then I would say, you need to re-calibrate the printer for that label.
If you were saying that the printer is printing on the right side of the label as you face the printer and watch the label exit the printer, then I would say, that the label size in the software is wrong, or the transfer ribbon is loaded incorrectly, too far to the right as you face the label exit path, OR the labels are loaded too far to the left as you face the label exit path.
Here is a link to a manual that may help as well.
Posted on Feb 02, 2008
ctf1800
  • 4402 Answers
SOURCE: Zebra Printing issue
turn off eof or blank page after eof
Posted on Mar 17, 2008
bartech9
  • 155 Answers
SOURCE: Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Posted on Mar 10, 2009
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
RoryMRP
  • 111 Answers
SOURCE: Zebra printer 140Xi, firmware 16.4.1, Labelview software 8.0. Click print a label which works on another computer and zebra printer and nothing happens
Try and reflash it again.
Posted on Jul 10, 2009
Hi Dear All, My printer is not printing ZPL
Only Zebra printers use and print ZPL. ZPL =Zebra Programming Language. Other printers cannot intrepret ZPL.
Aug 13, 2013 | Zebra RW220 PRINTER 2" DT RUGGED MOBILE...
Printing from coreldraw 5 to zebra p330i
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
Aug 08, 2012 | Zebra P330i Thermal Card Printer
I'm printing a double sided card. The back side comes out fine (white with black letters). The front side needs to be completey black with red letters. It keeps coming out blurry. How do I fix that?
It may be that the ribbon is mispositioned. There are quite a few points in the trouble shooting section of the owners manual. These start on page 53. Here is the link to the page at the zebra company site that you can download the manual from.
http://www.zebra.com/id/zebra/na/en/index/products/printers/card/p120i.4.tabs.html
Hope this helps,
Best Regards,
Mark
Dec 29, 2010 | Zebra P120i Thermal Card Printer
Error
Hi and thank you for using fixya:
You need to buy a new ribbon for the machine
Jun 03, 2010 | Zebra P420i Thermal Card Printer
Can I print in color with a Zebra 105se
Thermal printers don't have any 'color' of their own; the 'printed' text/numbers are actually only areas subjected to heat from the printhead which exposes the color of tiny beads of ink that are on the paper itself by melting them. Use a fingernail to 'score' the paper and you will see it change color just as happens in the printer.
Oct 14, 2009 | Zebra 105Se Thermal Printer
Zebra print jus blue color
The "i" is the newer series. You will run into problem trying to install the P310C with the P310i drivers. More so if you are running Windows Vista. In that case don't even try.
If your computer has excepted the drivers that you have. Go into the Printer Properties; General Tab; Printer prefs; Advanced button in the bottom right corner ;next, and change the Ribbon type. K is for Black 1 color ribbon.
Try YMCKO for Full COlor. If the ribbon is also YMCKO.
Yellow, Magenta, Cyan, Black, Over lay...
Jan 31, 2009 | Zebra P310I Printer
Zebra P120i Plastic ID Card Printer - P/N P120I-0000A-IDB Start Up Kit Logo
29 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
