Question about Suzuki 25Note Chromatic Tone Chime Set
Adjusting the volume on the tone chimes
Which setting on the rubber clapper is softest?
3 Suggested Answers
  • 5603 Answers
SOURCE: The clapper on the A#/Bb-6
Frankly, I would analyze what the clappers ar made of and MAKE them yourself. If they are plastic, find suitable material and make your own. If metal, you can have a metalshop make some for you.
Finding replacements either piecemeal or individual chimes is NOT likely to happen.
Posted on Aug 09, 2010
SOURCE: some of my tone chimes feel like they are gummed
There are 2 hex head screws at the base of the plastic piece that holds the clapper. Unscrew them a little, and it should loosen up the head.
Posted on Dec 04, 2012
Which is the master volume to boss me 25 ?
Hi, I can help you with your question. On the face of the effects, towards the right side, there are three settings that can be adjusted: DRIVE, TONE and VOLUME. The VOLUME knob is your master volume. The expression pedal can adjust volume, but it's output volume is controlled by the master VOLUME knob we just identified. I hope this has helped you, and if it has, could you please click on the "helpful" button ? Thank you!
Feb 03, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
How do i adjust the drum rhythm volume so it is louder than the tone settings
You ay have to edit a rhythm and save it as a "user defined rhythm". During editing the volume of each part can be defined with vol. level ranging from 0-127.
Please read the manual.
Metronome volume can be easily changed by just holding the metronome button.
Mar 22, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Some of my tone chimes feel like they are gummed up or something. The clapper head does not move freely. Any suggestions?
Sep 27, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Have a number of chimes that are out of tune...would like to have 2 octaves checked and replaced or fixed, as needed... also am missing one chime... how do we go about fixing our needs?
The tuning is NOT likely to change unless: Metal tube is damaged OR there is dirt or other buildup on the tubes OR there are cracks in the tube. Procure a Korg tuner to check the pitch of these. Do NOT compare against a piano since a piano is "stretch tuned" and may be off up to 22 cents.
The Korg chromatic tuners can be bought for about $20... they are precise. If chimes are cracked, or damaged, that is usually fatal. Dirt can be cleaned.
Jun 27, 2011 | Suzuki 25Note Chromatic Tone Chime Set
I am trying to replace several of my Suzuki hand chimes that are so out of tune I can't really use them anymore and can't find a supplier who will sell them individually. Can you help? I need 1 G-4, 2...
Suzuki does sell individual replacements, I bought a few last year. If there are a few unusable chimes now, you can try to tune them, nothing to lose, I was able to tune 8 of ours and 2 others were too far gone and had to be replaced. They tune like a tuning fork, which is what they are. If the chime is flat, you either file the tips, in effect making the legs shorter, this must be done evenly or sustain will be affected, or, the inside of the legs near the tips can be filed, again evenly, to reduce mass. If the chime is sharp, filing is done down in the "******" area.
Apr 25, 2011 | Suzuki 25Note Chromatic Tone Chime Set
E5 tone chime out of tune. Sounds flat. Have replaced the head and this has not solved the problem
Forgot to mention... the clapper has almost nothing to do with the tone.
Apr 20, 2011 | Suzuki Music
The head of my A6 chime has split. I need a replacement part, but have no idea where to get one. This is a very old classroom set that was purchased years ago. I'm not surprised that the rubber is...
You will have a near impossible task to find a replacement. Try at a music store that deals in student instruments. This is not high tech and the technology has not changed much so you might luck out.. DO NOT leave any part of your set with them... they tend to get lost.
If you can't get the part then your choice is to MAKE a suitable part. It is often not hard to come up with a substitute. If the metal of the chime has cracked, then have it welded and then tune it with a file...
Mar 09, 2011 | Suzuki 25Note Chromatic Tone Chime Set
I have a Suzuki tone chime C6 that is flat sounding. Is there any way that this can be fixed?
First inspect for mechanical damage such as cracks or dents. Do not confuse "flat" as off pitch with "dead" sound...
Get an electronic tuner and verify pitch before going further. If there is a crack, depending on the material it might be repairable. It is UNLIKELY that the pitch would be very far off as these are mechanical type resonators due to manufacturing defect. Also look for problem with the clapper...
Nov 24, 2010 | Suzuki 25Note Chromatic Tone Chime Set
The clapper on the A#/Bb-6 and C-7 chimes are broken. The clapper head is completely gone. Where can I get a replacement part and how is it installed. I have been searching the Internet for days to no...
Aug 09, 2010 | Suzuki 25Note Chromatic Tone Chime Set
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Suzuki 25Note Chromatic Tone Chime Set Logo
41 people viewed this question
Top Suzuki Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Suzuki Music Expert? Answer questions, earn points and help others
