Question about Coffee Makers & Espresso Machines
How to clean Oster 12 Cup Programmable Coffee Maker BVSTCJ0029-33A
IrishDruid
  • 2712 Answers
SOURCE: oster coffee maker
Looks like you will have to contact Oster directly. I am unable to find replacement pots asa standalone for sale. You can contact them here:
http://www.oster.ca/consumerservice.aspx?content=contact
Or you can call them at (800) 334-0759
Canadian Residents: (800) 667-8623
Posted on May 19, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
SOURCE: Need to clean my coffee maker
me to dont know, sorry
Posted on Dec 18, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
Posted on Mar 24, 2009
  • 85 Answers
SOURCE: My Cuisinart 12 cup programmable coffee maker will
Hello jimmarsh,
You are right, there is a way to fix this. This is really a common problem with this unit that is fixable.
I recently had this similar problem. If you still have your machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used an eyeglass screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 09, 2009
How to clean the coffee maker?
The easiest way is to run a cup of white vinegar in half a carafe of water through the brew cycle, followed by at least one carafe of clean water.
Jul 16, 2014 | Mr. Coffee 12-Cup Programmable Coffeemaker
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
My coffee maker wont brew
i cant clean it cause it doesnt pump
Nov 27, 2012 | Oster HDX23 12-Cup Coffee Maker
Can't find instructions for cleaning
You can buy commercial coffee maker cleaner at most places that sell coffee makers. Follow the package directions. Usually you just add it to a pot of water and run it through. Repeat the process, then run a couple of pots of plain water to rinse it. You can also use a pot of plain vinegar to clean the machine, but its a smell that many people find unpleasant.
Mar 21, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
How do i clean it
Do an internet search for coffee maker descaling solution. That stuff is designed to clean out the gunk from the insides
Nov 22, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
How to use clean cycle
Most probably find a Oster Coffee Maker manual here. Just send them a search request.
Apr 26, 2009 | Oster HDX23 12-Cup Coffee Maker
Hamilton Beach 12 Cup Programmable Coffee Maker
Here is a link to the manual for the model 43253 (model listed in your post's header). If this isn't your model, this link will take you to the download page where you can select your actual model.
Happy brewing! (I hope you're starting with whole beans and grinding them yourself...it's the only way to go!)
Mar 27, 2009 | Hamilton Beach (43253) 12-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
