How do you format lables to print properly on the richo e7000?
Trying to print out little 2 5/8 lables, and it cuts them off. How do I fix?
  • 1,087 Answers
Printing labels is a pain! It is much easier to print using an A4 sheet with (say) 7 rows of 4 labels on.
I suggest you use the Ricoh support site
http://www.ricoh-support.com/Enduser/support/
Posted on May 08, 2014
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
I have a panasonic kx-E7000 and some buttons on the keyboard work and some dont, is there a way i can fix the problem?
You can remove, disassemble clean with alcohol, put a little powdered graphite on the rubber contacts.
DickyO
Feb 09, 2014 | Panasonic Kx-e7000 Electric Typewriter
My printer always start printing short so that the lables end up on two pieces instead of one
We must establish whether the problem is a moving label or just that the labels are not aligned properly. Is hte printing split across the two labels consistant regardless of hte number of labels printed? If so, then the lables are not aligned properly. The user manual has the procedure for aligning these. This is part of the setup procedure.
If hte first line of the labels changes position on subsequent printings, then either the label size is not defined properly or the format being used is not correct. I don't have the manual handy at the moment so I can't give you the particulars, but if you could update this and tell me which of the 2 conditions you are experiencing, I will look up the specifics in the morning.
Thanks,
Dan
Dec 09, 2010 | Zebra Z4M Printer
Which CPU's are compatible with the dell optiplex 360 mobo ?
It will take at the best E7000 series Intel® Core 2 Duo 3M, 1066 FSB
Cut you can download the full pdf spec manual from here cheers from Scott and plz vote
Oct 17, 2010 | Dell OptiPlex 360 Desktop Computer
Printing from the wrong trey
Hi, your printer tray 1 is not detected by controler, so you need do:
1) change other tray box instead if you have same one, easy fix it
2) check tray 1 box back side, there is a sensor (optical sensor it does not work), you need find out a white lable stick around there, if the lable is not white enough, the optical sensor does not detecting tray 1.
hope help you fix it and answer your question any time, please rating me thanks
May 14, 2009 | HP LaserJet 4700 Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Problem printing Pendaflex file tab labels from 4600dn
Make sure the settings are properly set within the program and printer.
Jul 01, 2008 | HP LaserJet 4600dn Color Printer
Physical alignment of lable holder lost
pleasesir check its lock and screws for open it but take care
Sep 21, 2007 | SATO CX400 Thermal Label Printer
54 people viewed this question
jasbo
jasbo
