Question about Lands Phones
I have the Tomy Digetal Plus TD350 monitor. The walk about unit looses all charge and switches itself off. I have to open the back disconnect battery and replace for it to start again. If the walk about handset is placed back on the stand as soon as I've done this it switches off again. I have been using this monitor for thirteen months, it's been an issue for around 6 months. Please advise.
    New Friend:
  • 50 Answers
Replace the Battery
Posted on May 10, 2014
snakehead
  • 1074 Answers
SOURCE: Base won't charge handset
the base of your handset needs to be repair take it to a tech
Posted on Apr 04, 2007
SOURCE: Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Posted on Nov 09, 2007
  • 3 Answers
SOURCE: Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Posted on Nov 21, 2007
PyroPCMan
  • 405 Answers
SOURCE: Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Posted on Mar 12, 2008
  • 5 Answers
SOURCE: Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Posted on Jul 21, 2009
I lost a connection of tomy digital viedo srv400
Hello. I think I've worked this one out. Turn both on as usual. Go to the main menu screen on the parent unit and click on add camera icon. Then click camera one.... but before clicking the add button, go to the camera itself and click the power button as follows - two short clicks, then hold the power button - the green light will start flashing. Keep holding the power button on the camera and click the add button icon on the parent unit. They should pair. The camera may turn off then, but it should be paired - simply turn it on again. Worked on mine, but took a long time to work out how to fix. Please email if you need any help. hbmb8@bigpond.com
Oct 26, 2014 | Baby Gear
I have tomy classic baby monitor from a year now, from few days parent unit is beeping continiously, have checked connection and evrything and even the green light does goes red
The unit may have a back-up battery installed that is low on charge. Replace the back-up battery. The unit is probably still working because you have it plugged-in.
Sep 17, 2014 | Baby Gear
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    1981 Tomy Up Down Change Around Roller Coaster
    Our battery was dead and would not recharge . Batteries + Plus built me a new one. Problem is, motor is dead and am looking for one to fit.
    Feb 08, 2013 | Tomy Toys
    Tomy baby monitor srv 400 instruction
    Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
    follow these instructions;
    1. Place the Parent Unit next to the Baby Unit.
    2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
    2 seconds.
    3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
    4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
    press the Mode/ Enter Key to confirm your choice.
    5. The current status shall now appear, showing all four Camera Units shaded grey;
    6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
    the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
    7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
    8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
    Jun 05, 2012 | Baby Care
    Tomy walkabout platinum monitor
    Sounds like the battery - the parent unit has a rechargeable batter pack. You can get a replacement battery at most appliance stores.
    Regards.
    Apr 18, 2010 | Baby Care
    FA error code on screen Tomy Walkabout Platinum monitor
    Hi, I've had the same problem with the Tomy WalkAbout Platinum - and, indeed, no help to be found on any website.
    Eventually traced the problem to the temperature reset button on the child unit (the blue button to the side). This button was lodged solid in the device; on inspection because of the wire of the temperature sensor.
    I've opened up the child unit (remove the four small screws with a watchmakers screwdriver) and removed the entire temp. reset button.
    The set up works as normal (but with a bit of gap). With a bit more time, you might be able to fix the temperature sensor wire and get the temperature reset to work again.
    Regards,
    M
    Feb 21, 2010 | Tomy Freestyle Baby Carrier
    Ipod won't work unless plugged in to computer or mains
    alison65,
    good day, the only possible cause why your player can only power up using it's own charger or through pc connection is:
    1) The connection of the rechargeable battery inside the player is loose or out of contact
    2) The rechargeable battery itself is faulty
    3) The connection from the charging line is loose or out of contact
    most likely your problem is within the internal of the unit.
    cheers,
    mark
    Jan 29, 2009 | Apple iPod nano
    BT Problem Battery/Power Problem
    In my opinion it is always very risky to buy some second hand unit because you can not be sure if every hardware component works properly. The best solution for you is to contact service partner and let them check the PDA. It is also possible that power supply electronic has some malfunction
    Sep 08, 2005 | Toshiba e740 Pocket PC
    Lands Phones Logo
    20 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
