Question about Lexmark X7675 Wireless All-in-One Printer
My printer says it is offline I have a MacBook
Printer is connected the the wireless router and computer is connected but I cannot print from my computer to the x7675. When I try to re-add the printer by using the IP address it says unable to connect due to an error.
  • 43 Answers
Most printers you go into your computer where your printer is listed, find the printer right click mouse or pad, and you may see a line that says off line, click on it and many times it puts it back on line...
Posted on May 08, 2014
SOURCE: Print server thinks printer is offline
Disconnect from the net and turn off your firewall while trying to install.
Posted on Jul 31, 2008
CompuGuy44
  • 432 Answers
SOURCE: No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Posted on Feb 03, 2009
smartr10U
  • 1305 Answers
SOURCE: Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
Posted on May 28, 2009
  • 8 Answers
SOURCE: wireless printer gets ip address different from my routers ip add
Is the wireless network on you router secured? a 169.254.x.x ip is an invalid ip meaning, it's not connected wirelessly to the router yet.
Posted on Apr 18, 2010
cirocpatel
  • 524 Answers
SOURCE: User's Guide does not contain software installation instructions.
I would recommend you to reinstall the driver from the below link. also if you click on Technical support - How to install downloaded driver it will show you how to install it.
-http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X6570/catId=cat10004-category&prodId=4165-product;jsessionid=36351499255753845B8F3686DDD5E41C.node3
Also in the related links there's user guide for the Printer. it has instruction on how to configure network on your printer.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on Apr 30, 2010
My router isnt sending signal to my printer
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Jan 11, 2013 | Linksys Wireless-G WRT54G Router
Can i connect Hp F380 all in one printer to Linksys wrt54g, and i am using macbook, help
From looking at the printer information and the router information, you will probably need additional equipment to make this work.
The printer connects to computers using a USB cable. It does not have a network connection, either wired or wireless built in.
That means you need a print server to connect your printer to the network. Some routers have a print server built in, but the WRT54G isn't one of them.
The print server will have some USB ports to connect the printer to, and connect to the router with a cable, or wirelessly.
HP shows this option: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01428401&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&key=null&product=1128296
If you can find that one, it might work the best. Many print servers have a hard time with all-in-one devices. They are usually able to print just fine, but scanning is troublesome. Make sure to review information about any print server you get, or router with built in print server to make sure it does everything you need.
Considering the price of a print server, it might be a better option to get a new printer that has built in network support. They are more likely to work easily and well. But watch carefully to make sure it can do everything you need (print, scan etc) over the network.
May 04, 2011 | Linksys Wireless-G WRT54G Router
How do I connect wireless my MACBOOK & HP PHOTOSMART C4480
You need to connect your printer to a wireless router in your home/office. Once it's connected successfully, you then run the HP software on your computer and it will ask you how you want to connect to your printer. Select the option "Wireless" and then it will search your network for the IP address of your printer and then you should be able to print wirelessly to your printer.
May 04, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
My Printer is offline and will not print
Hi!
If the printer says offline, the initial step that you need to check is the physical connection. If it is a USB printer, verify if the USB Cable is properly connected on both ends (PC to Printer and vise versa). If it is a network or wireless printer, make sure the printer is connected to your network. For wireless printers, you can easily identify if its just the wireless settings problem by connecting your printer hard wired to your wireless router. After you hardwired it, go to Printers and Faxes for XP, for Windows 7 and Vista click on Devices and Printers on the Control Panel. Right-click on your Printer icon then select "Use Printer Online" then try to print a test page.
Regards!
Feb 18, 2011 | Office Equipment & Supplies
Just set up cannon PIXMA MX870 printer. Cannot get it to print from wireless connection. In my printer box it says the printer is offline. It will print when I connect the printer with a cable. I use a...
I had the same problem - my printer showed that wireless LAN was enabled & my mac showed the printer but said it was offline. I went to preferences, print & fax, hit the + key to add a printer, added the canon printer again, set that printer as my default, did a print command from Word & that created a queue in the new default printer ... and it printed. Deleted the first Canon printer that was "offline." Oh, and I'm not sure if it made a difference, but before what I just described, I checked for software updates after the printer CD install process & uploaded one update.
Jan 27, 2011 | Canon PIXMA MX870 Wireless Office...
I just bought a Macbook Pro and a multifunction Canon printer. I can print only if the computer and printer are connected with a cord. I am unable to printer wirelessly and the status says 'offline'. How...
You may find this page useful (you also need an Access Point, but I assume you have one and it's configured correctly - don't you?)
http://www.derekunderwood.com/uncategorized/go-wireless-from-mac-to-canon-pixma-mp460/
Let me know.
Mar 24, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
The internet is connected but not able to print using laptop..says the printer is offline but its not..
ok now have to setup the printer as a network printer on your computer because if you havent you wont print to it. if not you need to allocate an IP address for it so it doesnt change each time you turn the printer off and then setup the printer on your computer. good luck with that
Aug 31, 2009 | D-Link DIR-625 (790069292637) Wireless...
Printing wirelessly from my macbook
Can you check to be sure there is a relationship between the laptop, printer and access point? All on the same SSID?
Jul 06, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Lexmark X7675 Wireless All-in-One Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
