Question about Servis M4904
My servis tumble dryer m2002w wont turn theres power ,belt is fine and it heats up
    Top Expert:
  • Servis Master
  • 3,698 Answers
Does it turn by hand? Bad bearings?
Posted on May 07, 2014
Maytag neptune dryer heats but wont tumble
When you spin it by hand, is there resistance? Can you hear the motor turning? In fact, when you switch it on and it starts to heat, can you hear the motor turning, or is it silent?
Sounds like the belt is broken, in which case there will be little resistance.
If there is resistance, it may be the motor or circuitry controlling the motor.
Aug 24, 2015 | Maytag Dryers
Replacing belt on service tumble dryer
see this videos and fix it. use the common sense. God bless you
Sep 30, 2012 | Hotpoint Creda Servis Tumble Dryer Belt...
My servis M2002 tumble dryer will only turn after being manually started off then shutting the door quickly. It will then stop and hum when it trys to go in reverse. Any ideas what it could be?
I would say motor but here is a website to help:
drum roller/glides, idler assembly:http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 11, 2010 | Dryers
Servis tumble dryer drum will not turn
If motor is sounding quieter than normal more than likely the belt has broken.
Jan 31, 2010 | Dryers
Kenmore dryer 75731 won't tumble. It heats fine.
Hi.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
Dryer heats up and is getting power, but the door
door switch is fine or it would not heat or do anything
more than likely its a bad belt
Oct 08, 2009 | Dryers
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwashers Logo
42 people viewed this question
Top Servis Dishwashers Experts
Eric Taylor
Gil Davis
Are you a Servis Dishwasher Expert? Answer questions, earn points and help others
